Spl Subwoofer and set budget to be powered by a kx1200.1
Username: Torn
Post Number: 489
No kicker subs pls! looking to spend about 225$ for 1 or 2 12" or 10"s To be wired to 1 ohm on the amp, birth sheet says it does 1,500 power for the amp. Looking for SpL woofers. Looking for many suggestions and scores for the suggestions that you have seen for the woofer if possible.
Username: Nd4spd18
Northwest PA
Post Number: 5966
Audioque HDC3
Username: Stateprop486
PA
Post Number: 231
2 AQ SD2.5, 12s is $139 each r 10s $129 each.
Username: Talon01
Team revolution , Pa Usa
Post Number: 805
i would say 2 10" aq 2.5 depends if you are running a specific class
Username: Denali_on_22s
The kids like my rhyme...
Post Number: 3820
2 2.5s will give you the best spl
Username: Torn
Post Number: 491
Is there Any single sub to 1 ohm for the price that would Give better spl than AQ's out there or is this my best bet?
Username: Torn
Post Number: 494
Post Number: 3830
that's your best bet
