How to securely screw into car sheet metal???
Username: Mendonmafia
Post Number: 911
anyone know how to do this. just about every time i try to i strip/bend the metal so that it no longer holds the screw and even if i do get it to work it usually dosnt hold very well.
Username: Safe_cracker
Chicago, IL US
Post Number: 4016
Then your not using sheet metal screws. I just drill a pilot hole and use the screw to finish it. Most good sheet metal screws are self tapping, never had a problem...Polo..
Post Number: 912
i am using sheet metal screws its just that the sheet metal is shitty and bends really easy.
Username: Rovin
4 10 Pioneer...
Post Number: 12945
then use a bolt & nut ....
Post Number: 913
i have no way of getting a wrench on the other side of the metal.
Chicago, IL US
Post Number: 4017
Then don't overtighten them! They make everyones cars out of the same metal as yours, your the only one with this problem hahaha lmfao.. Polo.. :-O
Username: Nd4spd18
Northwest PA
Post Number: 5899
Yeah, drill pilot hole and use self tapping sheet metal screws, you shouldn't have a problem.
The only time I ever had a problem drilling through sheet metal was when I was drilling two 3/4" holes for 2 runs of 1/0 wire, in a non-flat spot.......
Username: Prostreetamx
Las Vegas, NV United States
Post Number: 7
Use nutzerts and machine screws. Nutzerts are installed in a hole and installed with a tool that is similar to a rivet gun. They expand and lock into place from the front. You don't need to get at the back.
Username: Van_man
Boston South, MA
Post Number: 3328
toggle bolts, hollow wall anchors, locktite, or proper screw incertion practice.
What are you screwing into? tin foil? I use fine thread drywall screws and have never had a problem. I also use self tapping "tech" screws to predrill if nessisary.
Post Number: 953
idk i guess my car has shitty sheet metal or somthing becsue the screws directly into the metal do not hold no matter how hard i try it simply just strips out the fine threaded sheetmetla scresa and the heaver threded screws just bend the metal and the screw falls out.
Richard thoes nutzerts sound like what i need. where can i get them?
Chicago, IL US
Post Number: 4031
There is no such thing as fine threaded sheet metal screws, dude your using the wrong sh!t. The self tapping don't even require a hole, it makes its own. I have metal screw with 5" L bracket holding my box down, will never move, never loosen guarranteed ... Polo.
Post Number: 955
well i was just reffering to the thred being finer than other screws i have tried. and i know what a self tapping screw is thoes are what i tried to use the first time but the hole just bent out instead of tapping isk it was werid. i think it might have to do with the fact that the metal i am trying to screw into is not flat be any means it sort of is like convexed out a little bit.
Chicago, IL US
Post Number: 4033
Pictures?
Post Number: 956
maybe tommrow if i get home at a reasonable hour i have class in the am from 8am-830pm and its already 11 where im at now so im bout to go to bed friday i can put some up tho if i dont already fix it by then (most likely wont be able to).
Post Number: 10
I got my Nutzerts off Ebay along with the tool to install them . Use the steel versions as the aluminum ones rip out the threads when you install them. The kit will come with aluminum zerts but buy some steel ones seperatly.
