Need an amp, 1-2krms at 4ohms
Username: Rideredder
Cornell, IL USA
Post Number: 1319
Other than the kx2500.1, what are some other amps that put out between 1000 and 2000rms at 4ohms? I'm looking for an amp for a Sound Splinter RL-s.
Username: Drant19
DUB-C, TX
Post Number: 245
whats the vc? and why 4ohm? if its dual2ohm then drop it down to 1...if its a dualohm then drop it down to 2...
Cornell, IL USA
Post Number: 1323
It's a single 3ohm.
Username: Drant19
DUB-C, TX
Post Number: 252
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=471
does 1200rms from 1-4ohm
Username: Nd4spd18
Northwest PA
Post Number: 5650
JL Audio 1000/1
Username: Rossx1
Nashville, AR United States
Post Number: 20
us amps md3d
Username: Nd4spd18
Northwest PA
Post Number: 5685
Kicker ZX1500.1 would also work...... it's 750 at 4 ohms and 1500 at 2 ohms, and underrated.
You would probably get a little over 1000w at 3 ohms from it.
Username: N2audio
Lawrence, Ks USA
Post Number: 1460
~1300 @ 3-4
Username: Nd4spd18
Northwest PA
Post Number: 5696
^^^^ isn't that the same amp abarca posted
Username: Drant19
DUB-C, TX
Post Number: 267
yep lol
Username: N2audio
Lawrence, Ks USA
Post Number: 1461
ah, guess so - I hadn't even looked at previous suggestions -- quick post and run
Cornell, IL USA
Post Number: 1337
What would the RF T20001bd put out at 4ohms? That's the amp that I really want. I know some people claim upwards of 3000rms at 1ohm.
Username: Drant19
DUB-C, TX
Post Number: 301
"some people claim upwards of 3000rms at 1ohm."
truth.
make a new thread about the T20001bd. im sure a few people on here have had experience with the amp. i would make the thread in the subwoofer section tho. theres a few cats who dont like that, but thats the section thats got the most traffic
Username: Southernrebel
Monroe, Louisiana 2 DD3515s, 2...
Post Number: 5868
I vote PG X1200.1, cause its so dam sexy
