Dual 8285 Bypass?
Username: Btlew81
New here...want to get the dual 8285, but also want to bypass so I can watch while driving. Would I use the same CD/DVD method mentioned for older duals? I desperately need some quick help!
Thanks
Username: Barbamil
MoscowRussia
E-Brake wire still grounded at the Steering Column area
** Insert a DVD and let it play until you hear sound
** Using the remote control, Press the STOP button twice
** Enter 26604
** Press OK
Username: Barbamil
MoscowRussia
Please, how to multizone a Dual XDVD 8285.Thanks.
Username: Tone602
Az
this also worked for my Dual 8183 dvd player...
thanx
Username: Cyberalexander
Hello, I have a Dual xdvd8285 applies the code for parking bypass, but now when placing the screen in stanby, it is placed in black only about 5 seconds and then reappears video, it is not applied according to the Standby screen, I do? Has something to do bypass brake by code? Thanks.
