!!!!!!!!HELP on charging system upgrade!!!!!!!!!!!!!!!
Username: Djhasanicesoundsystem
Vista, Ca Usa
Post Number: 170
so i was thinking about getting 2 12" RE SX's and a kicker amp(what ever will handle those 2 the best) BUT will i have to upgrade my charging system?
Username: Kingandsons07
Lincoln, Nebraska U.S.A
Post Number: 349
well it don't hurt to do the big 3 i would think a kicker ZX1500.1 should do it! but u need the dvc 2Ohm for it to work
Username: Denali_on_22s
You can call me Scroog...
Post Number: 3241
nah 2500.1 for sure on those SXs... prolly won't even have to watch your gain that much if you know what you're doing
Username: Th3pwn3r
Post Number:...
Post Number: 6121
Of course he has to watch his gain or he'll clip the piss out of the subs...on the other hand if his ears are any good he'll know when distortion is present and turn it down.
Username: Frkkevin
Post Number: 4207
weve run sx 12s on a ss 6500.. they can take a lot of power on a proper charging system..
for those subs i'd not run anything under 2000rms.. they are not very efficient and need power to make them shine
this being said.. minimum big 3 and good batt or two.. just don't use the gain knob as a volume control and youll be ok until you start running up in the power range
if your gonna play it loud most of the time.. get an alt or youll regret it when you clip and amp/sub to death
Username: Nd4spd18
Northwest PA
Post Number: 4406
ZX2500.1 would be the best Kicker amp for those subs.
And you will absolutely need an HO alternator to run that amp.
Vista, Ca Usa
Post Number: 171
well what alternator would be the best/ cheapest since the amp and subs are costin me ALOT. im runnin outta money. OOOO and how would i run a second battery?
Username: Nd4spd18
Northwest PA
Post Number: 4431
You only need one battery. And alternators aren't cheap.
Username: Big_edge_head
Milwaukee, Wisconsin USA
Post Number: 891
no they arnt
