Earthquake....
Username: Winterfreshpimp
Chisago, MN America
Post Number: 573
Earthquake PHD5000W
Would this amp actually produse 3000wrms at 2 ohms?
Chisago, MN America
Post Number: 574
Produce*}
Username: Nd4spd18
Northwest PA
Post Number: 4186
Highly doubt it
Earthquakes quality sucks too...... they're one of the more common amps I see blown
Username: Livin_loud
Do Work Fi Audio
Post Number: 1953
old school EQ ftw
Username: Mixmastaspig
Canada, Canada Canada
Post Number: 1251
I had the D-10 (PHD-10,000) and it is also rated @ 3,000rms @ 2ohm. I switched to my RD amp and I almost gained 3db so I would say the Earthquake can do close enough to rated power.
Username: Nd4spd18
Northwest PA
Post Number: 4196
3db is a BIG difference........ what RD amp did you switch to?
Chisago, MN America
Post Number: 576
Okay any other opinions?
Thanks for the input
