Silver Member Username: Dj_excitePost Number: 133 Registered: May-04 | i got a pair of audiobahns a friend gave me the rubber surround is beet up so i was thinking of fliping them inside out i have done this b4 but in a bandpass box not sealed .....how would it sound should i or no |
Gold Member Username: Naledge503Http://com4.runboard.c... Post Number: 2234 Registered: Jun-06 | No sound difference. Just for bling factor. Which will work perfect cause you got the bahns..![]() |
Gold Member Username: Logan__tilleHEMIKLR Post Number: 9073 Registered: Feb-06 | It might sound a little bit boomier, but you probably wont notice. |
Gold Member Username: Th3pwn3rPost Number:... Post Number: 5915 Registered: Jul-06 | "It might sound a little bit boomier, but you probably wont notice." Why would it sound "boomier"? |
Silver Member Username: Dj_excitePost Number: 134 Registered: May-04 | i think he saying it will sound boomier since the speakers are more exposed to the trunk and it will b using the trunk as another box.........i dont no thts wat my common sense is telling me![]() |
Gold Member Username: Logan__tilleHEMIKLR Post Number: 9074 Registered: Feb-06 | Because Rob, It will have more box volume when you invert it. |
Silver Member Username: CblazeRock island, Tenesssee Us Post Number: 479 Registered: Sep-07 | audiobahns are not my fav,but i guess u cant complain since they where gave to you.id just seal them and be done with it |
Gold Member Username: Th3pwn3rPost Number:... Post Number: 5922 Registered: Jul-06 | "Because Rob, It will have more box volume when you invert it." So the more volume you have in a box makes it "boomier".Hmm...I'm going to make a 40 Cu Ft box because it'll be boomier than my box that's 16 Cu Ft.Sweet! |
Gold Member Username: Nyyfan13Fi SSD USA Post Number: 7090 Registered: Jul-06 | http://www.glasswolf.net/caraudio/inverted.html |
Gold Member Username: Van_manBoston South, MA Post Number: 3108 Registered: Mar-06 | may want to reverse the polarity too. Try it both ways, and see what works better. |
Silver Member Username: StamantLA, FL USA Post Number: 330 Registered: Sep-04 | How do you reverse the polarity of the subs? |
Platinum Member Username: GlasswolfWisteria, Lane USA Post Number: 12103 Registered: Dec-03 | http://www.glasswolf.net/caraudio/inverted.html |
Platinum Member Username: WingmanaliveA pic is worth 1000 posts!! Post Number: 11175 Registered: Jun-06 | I'm seeing double.![]() |
Gold Member Username: Nyyfan13Fi SSD USA Post Number: 7094 Registered: Jul-06 | i have the exact same post as glasswolf....that means im as smart as him in this thread ![]() lol |
Platinum Member Username: WingmanaliveA pic is worth 1000 posts!! Post Number: 11179 Registered: Jun-06 | Lol, yeah but they're both pointing to HIS website. Beat that. |
Gold Member Username: Nyyfan13Fi SSD USA Post Number: 7096 Registered: Jul-06 | lol im gonna overlook that fact paul |
Gold Member Username: Logan__tilleHEMIKLR Post Number: 9078 Registered: Feb-06 | Yep Rob, thats pretty much it. The bigger the box, the louder it will be ![]() |
Platinum Member Username: Bestmankind-apem Post Number: 15752 Registered: Oct-05 | "i have the exact same post as glasswolf....that means im as smart as him in this thread lol" ![]() |
Gold Member Username: Nyyfan13Fi SSD USA Post Number: 7098 Registered: Jul-06 | ![]() |
