New member Username: Jrad12345Post Number: 10 Registered: Oct-07 | lookin at buying a new deck and i was wonderin if it is worth gettin this one it costs 300 on internet + dutys and stuff This is the deck Dual XDVD700 thanks in advance |
Gold Member Username: J_baby15Murray, Kentucky Post Number: 2062 Registered: Feb-06 | id shop around a bit more...depends on what your wanting it for, itd work, but if ur lookin to put together a quality system I'd go with somethin a lil better. I've had bad experience with Dual decks in general tho. |
Bronze Member Username: Jrad12345Post Number: 11 Registered: Oct-07 | Well i was comparing that deck and this one (Lanzar SDBT77N) which do you people think is the better buy This one costs 350 on internet + dutys and stuff |
Gold Member Username: MgbcsLincoln, Nebraska Post Number: 1760 Registered: Dec-06 | Well, I wouldn't suggest Lanzar or Dual. How much are you looking to spend, and what are you looking for in a deck? |
Gold Member Username: J_baby15Murray, Kentucky Post Number: 2065 Registered: Feb-06 | Id take the dual over the lanzar, but like BCS said...shop around some more...thers much better out there for not alot more. |
Bronze Member Username: Jrad12345Post Number: 12 Registered: Oct-07 | well im lookin to spend around 350 tops then add dutys n shipping so i guess like 450-500 off the internet but i want a 7 inch deck doesnt matter if its touchscreen i want it to play wma mp3 all types of burnd dvd's and cd's and it has to b retractable and have good eq like bass and treb n stuff but if its missin some of that but has lots of the rest then thatll b fine |
Gold Member Username: The_image_dynamicSan Diego Post Number: 3122 Registered: Dec-06 | I would hire a wetback to sing to me before I bought either of those decks. |
Gold Member Username: Tatonka-[Team Audib... Post Number: 1035 Registered: Mar-07 | Lil rob is around here somewhere Brad.... |
Gold Member Username: The_image_dynamicSan Diego Post Number: 3123 Registered: Dec-06 | ^^^ Racist |
Platinum Member Username: WingmanaliveA pic is worth 1000 posts!! Post Number: 11187 Registered: Jun-06 | ^^^^ Where is our mexican friend? |
Silver Member Username: Dubmc23Rapid City, SD USA Post Number: 112 Registered: Sep-07 | yea shop a bit more you can get a hell of a lot better then dual... |
Gold Member Username: Tatonka-[Team Audib... Post Number: 1036 Registered: Mar-07 | "I would hire a wetback to sing to me before I bought either of those decks." |
Gold Member Username: The_image_dynamicSan Diego Post Number: 3124 Registered: Dec-06 | |
Platinum Member Username: WingmanaliveA pic is worth 1000 posts!! Post Number: 11189 Registered: Jun-06 | ^^^You ain't right lol. Funny, but not right...... |
Silver Member Username: Cplaya280Quakertown, PA USA Post Number: 792 Registered: Oct-05 | i would get this over both of them.. http://cgi.ebay.com/Panasonic-CQ-VD7003U-7-Motorized-In-dash-Car-LCD-DVD_W0QQite mZ120185416541QQihZ002QQcategoryZ32825QQssPageNameZWDVWQQrdZ1QQcmdZViewItem |
Platinum Member Username: Rovin4 10 Pioneer... Post Number: 12500 Registered: Jul-05 | for $300 i wouldnt buy those brands look for pioneer\premier , alpine , clarion , eclpise ... |
