Using XBOX 360 in the car
Username: Ric416
Virginia Beach, Virginia USA
I have a 2008 tahoe with the nav and dvd system what would be the best way to run/hook up the xbox 360 system in this suv?
Username: Dkchillin
Vermont
Post Number: 493
Pretty basic, all you need is a power inverter that you would hard wire or just plug into the cig lighter and then connect the XBOX with whatever inputs you have on your dvd system (rca, s-video, compenent, etc). The hardest part is finding a good place to put the XBOX and figuring out how you want to mount it but there are nearly endless options there.
