Like
Wiring
Closed: New threads not accepted on this page
  Thread Last Poster Posts Last Post
Archive through September 02, 2006JENIFER CONTRERAS100
Archive through June 09, 2006reji eapen100
Archive through March 30, 2006anthony gavell100
Username: Jenifer_contreras
Tampa, Florida USA
Post Number: 158
mela,girl...change bf.
Monday Mike W. Lee will be back...He gonna help you!
Username: Drm035
Darlington, SC USA
Post Number: 25
I am trying to hook up a pioneer cd changer to my 97 ford taurus. We have taken out the factory radio but can not find the antenna plug to hook up the fm modulator, what can we do from here?
Username: Leew
Ketchikan, ALASKA USA
Post Number: 609
for mela from ottawa:
application/x-zip-compressedUpload
Chevy Malibu 1999.zip (31.8 k)
Username: Leew
Post Number: 610
for Becky Bryant:
There is no direct antenna plug in your oem HU
ford taur.zip (62.2 k)
Username: Leew
Post Number: 611
for Becky Bryant: what I posted above its wrong one!
this is for you:
ford taur.power antenna.zip (10.0 k)
Username: Mela
Ottawa
i love-ed you mike...i love-ed youuuuu!!!!!
heh thanks =D
Username: Leew
Post Number: 617
ah mela! if Jenifer will see that she will kill me...or cut something!
any time!
Username: Lewis12345
ford windstar 2002 and chevrolet corsica 1989
Tampa, Florida USA
Post Number: 195
lewis,for ford radio schema with rear/controls
1989 Chevy Corsica radio.zip (18.1 k)
2002 ford windstar.zip (40.2 k)
thx
Tampa, Florida USA
Post Number: 197
you welcome!
JenConBodyShop. Upload
Username: Ct0366
Sturgeon Bay, Wisconsin USA
My girlfriend accidentally cut the wires on the old wiring harness for my ***1998 Oldsmobile Cutlas Cierre***. So now i cant hook up my new deck. Does anybody have a wiring diagram for the original colored wires so i can match them to the wires of my new deck? It would be gratly appreciated
Username: Joball70
hi....i have a '92 ford thunderbird and am trying to put back the old factory radio and of course all the the wiring/harness was cut off by prev. owner.......right now am trying to reconnect the factory harness to the car's wiring.....speakers are done.......all that remains is a yellow/black wire, a green/black wire, the black ground, and a gray/red striped wire......when i connected the car's yellow/black wire to the harness yellow/black nothing happened....but when i connected the car's yellow wire to the harness's green/black wire an old tape ejected from radio.....i cant get any illumination on the radio either.....appreciate any help ....thanks
Username: Ct0366
My Bad its for a 1988 Oldsmobile not a 1998
Tampa, Florida USA
Post Number: 202
Charles Thomas! never ever give to Lady knife,
next time can be.....
This what you asked:
1998 olds.zip (69.3 k)
Tampa, Florida USA
Post Number: 203
ooo sh!t....
Tampa, Florida USA
Post Number: 204
ok...Charles Thomas take this:
1988 Olds.zip (41.1 k)
Tampa, Florida USA
Post Number: 205
and this is for small j
1992 ford thunder.zip (54.1 k)
Username: Ct0366
thanks for the file:-) Now will all the old wires be compatible to the new wires? ie: remote start and illumination.
Username: Ct0366
Also my deck i a flip-top and when i was trying to hook up the power wires last week i could only get it to move half way down.... what could cause that?
Username: Jean57
BradfordUnited kindom
need wireing diagram for ford fiesta 1995 for actory fitted radio.red,black .yellow,yellow/grey.thin brown.thick brown.got a new cd player to put in wireing is red.black. two orange any on no which wires go to which.
Tampa, Florida USA
Post Number: 206
yea, if you connect it by the schema,batt. to batt. speakers to speakers...e.g.100% you get it!
Also my deck i a flip-top ....
You have to connect safety wire from your new deck to parking brakes wire...it stays on a emerg.brake pedal(one wire)!f it dosn't help,then it something with head unit.(read the owner manual!)
Tampa, Florida USA
Post Number: 207
jean harvey
sorry,only for american cars
Username: Micaelowe
I have a 2000 Ford Escort ZX2 and pretty sure the amplifier is bad (two different factory radios, neither worked). Can you help me find either an Amplifer Bypass Harness (later used to upgrade stereo) or suggestions on where to find a new OEM amp. Thanks!
Username: Ct0366
Thanks, i finally got everything hooked up right and kept questioning if i did it right because it wouldnt turn on. come to find out it was the fuses...but i replaced them and now it works beautifully. Now i just need to hook up my amp but im not sure what to do there.. could you help me with that too
Username: Tbag
Looking for wiring schematic on 1999 Camry. An aftermarket alarm has shorted out and we are looking to disconnect it.
Username: Fordowner18
Menasha, WI United states
Looking for wiring on a 2002 FORD F-150 EXTENDED CAB. if you could give me a diagram, that would be great. Im looking to put some speakers in the back. and mess with the radio in front but i need a diagram. if someone could put in on here asap! THANKS!
Username: Trainer100000
Looking for wiring on diagram for a 95 Ford Escort. I viewed the diagram in one of the earlier posts. it does match the wires at the speakers but somewhere between the speakers and the factory radio the wire color changes this is a factory radio that is being replaced. I have tried using different wires with no luck. Any idea?
Tampa, Florida USA
Post Number: 281
I think you got oem Amp,that is why it does match the wires!
Tampa, Florida USA
Post Number: 283
ok...here we are,this is what you need...
1995 ford escort premium radio.zip (28.3 k)
Thats it exactly. This is great. Thank you SOOOOOOOOOO MUCH
Tampa, Florida USA
Post Number: 285
de nada!
WELCOME TO JENCONBODYSHOP!
looking for wiring diagram for a 2002 Ford F-150 EXTENDED CAB
THANKS
Tampa, Florida USA
Post Number: 298
ok,if you need it...take it:
this is w/out oem amp and rear control...
2002 Ford F-150.zip (20.9 k)
Username: Grealy
Apex, NC USA
Does anyone have a wiring diagram for a 2002 Ford Explorer with CD/cassette?
Username: Tort
Post Number: 53
I do,
Username: Raziel212
BLOSSOM, TX Usa
i have a 2000 mitsubishi eclipse and i put an aftermarket cd player in it and i had no volume could someone help me out please.
Username: Nall_one
i need the wiring diagrams for a 90 thunderbird, and 94 thunderbird cuz the last owner cut the plugs off my 90 and i got new ones out of a 94( same plugs but the wire colors are different)
Username: Leew
stealth fighter , Yokosuka, ... SPESNAZ. E...
Post Number: 794
Brian O'Connor! Check it Here!
Username: Jhall86
I have a 1990 ford escort the stero got jacked and now I am putting in this new stero but I have no clue which color means which in my car
Username: Christhunder
Can I Get the Color Codes for a radio in a 1997 Ford Taurus Without the CD Changer
Username: Up2nogood
Melbourne, Vic Australia
if anyone knows how to connect a head unit in a house so its like a car system but in a house email me at bored_lets_chat@hotmail.com
Username: Leew
XXXX!!WWWW, Yokosuka, ... SPESNAZ. ...
Post Number: 923
Chris! a 1997 Ford Taurus with Amp(premium sound) or not?
Username: Hollywdtm
I need an diagram and where is the Factory amp location for my 1992 Ford Taurus LX 4DR Sedan
i'm putting an JVC CD Player and my stepdad cut the plugs now i'm looking for an diagram and location of the factory amp.
reply here ok
p.s Please include some pictures/color
I dont think it is premium sound, im not to sure
Username: Avega12
Im trying to set up a deck in a 89 jeep cherokee and I dont know the wiring diagram or which colors go where so if I could get that that would be awesome.
Username: Avega12
Username: Leew
XXXX!!WWWW, Yokosuka, ... Holla Back Y...
Post Number: 1103
antonio david vega
Count all wires...and give me all wires color! Then I can help you out....
holla back
Username: Stixty
Mtl, Qbc Canada
Hello, I need information to install my reader Sony CDX-4050 in my Taurus L 1991 family. All the wire are cutting.And I don't know the function of wire. I'm sorry my english is not very good...
Username: Sasquatch_2169
I need a list of what wires are what to hook up my radio. My car did not come with a manual. it is a 1995 Ford Escort LX. The person who had it cut the wires for the wiring harness. I need to know which wires are which so i can hook up my radio. I have also been told my car has a built in amp. I need to know how to wire in the stereo the proper way with a built in amp.
Username: Shutterleftopen
Columbus, Ohio United states
Post Number: 157
can i get wiring for a 1996 toyota camry? or where i can find one. i'm trying to hook up my HU and not sure which wires are which. when i bought the car someone had already put in a deck and they were horrible with wiring.
Username: Zo686
Hey guys i just bought a 1994 ford escort hatchback and i wanted to install a new deck into it and being the stupid person i am...lol..i cut the wires for the harness that has the power because i didnt know that i could just buy a harness to connect to that harness, the speaker harness tho is still intact but anyways now i want to put the wires back into the harness and the problem is that i forgot which wires go into which slots in the harness...is there anyone who can help me with this problem PLEASE!!!
Username: Mysubsatemytrunk
I realize there will probably be multiple things that can cause this but any help or suggestions would be great I have a 2001 grand am with premium sound package (monsoon/ however no factory amp) I recently for the second time put my Pioneer 6800 in and recieved no sound , i decided to just use my hi-level input for my amp and re-install my stock radio it worked fine for about 30seconds the just shut off (no fading no pop just switched off) since then I have not been able to power either radio and I have checked all my fuses and everything else in the car electrical is working fine what my assumption is a short somewere however i've never had this happen (**also the lights on my radio except the LCD are working**) any suggestions are greatly appreciated I cant drive with no music another day.
Username: Mmichaels
Cumberland, Maryland
I }WAS WONDERING IF ANYONE COULD TELL ME THE COLORS OF THE SPEAKER WIRES FOR LEFT FRONT, LEFT REAR, RIGHT FRONT, AND RIGHT REAR OF A 1997 FORD EXPLORER WITH PREMIUM SOUND?
Username: Longgtr
HI really a noob but i have a 93 camry and i was installing a pioneer deck today according to the site below. http://www.installdr.com/Harnesses/Toyota-Wiring.pdf
but the deck would not work. Any comments would be aprreciated.
Also on that site it says DO NOT USE connectors J, N and P. Why is this so?
thanks
Username: Besum1
Does anyone have a wiring diagram for a 2001 Jeep Wrangler factory stereo system?
I need the diagram or color codes more less for a 1997 Ford Taurus Premium Sound Radio It would really help out, please and thanks
Username: Leew
XXXX!!WWWW, Yokosuka, ... YAKUDZA JAP...
Post Number: 1248
Chris
Click HERE!
Username: Leew
Post Number: 1249
Ben
go to my web,you will find it there Click Here!
Username: Jeepxj
hey can i plz get a wiring diagram for a factory radio for a 1990 jeep cherokee
Username: Crusadertanker
Fort irwin, Ca Usa
hello i need help on getting a factory wiring diagram for an 05 jeep liberty
Username: Blueskyjeeper
I am looking for a wiring diagram for my 1991 Jeep Cherokee. My radio got jacked and all thats left is a mess of wires.
Username: Pisatel
Chicago, IL USA
Hi guys, Please help me to find wiring diagram for car audio. 1999 Ford Econoline E-150
I could not find wire harness in any of the stores. They are for sale on Ebay, but it takes around 1 week to get it.
Can't wait so long.
Thanks a LOT!!!
Username: Arohed
Denver, CO USA
need help with color codes to wiring where my head unit used to be for '98 jeep Gr Cherokee Limited, with infinity gold sound. please and thank you
Username: Ghost0408
I have a 97 dodge grand caravan.someone hacked off the connectors for the radio.I need to know what color wires are for what speakers so i can install my new cd player.....any help would be apprieciated....thanks
Username: Bigsexymike2lee6
does anyone have the stereo wiring color codes for a 2001 chevy malibu?
Username: Drock10
does anyone no where i can find a wiring diagram for a 97 f150. or can give me one
rugbydude911@gmail.com
Username: Astrosurfer
i have a chevy malibu 2001
unable to locate this pink wire for antenna trigger...do not have a pink wire at all back there in dash....well i do but it goes to the hazard switch...so that cannot be it..i'd imagine this wire would be part of the plug which went into my original factory stereo.
installed a sony F7715X stereo a while ago but have always had a fairly poor reception on fm...am i don't use...and the wife is aggravating me about it too...
used a standard GM plug adapter for wiring and all wires used except for a purple, gray and blue i think...i know i got to connect my antenna power wire from the new sony...but this pink wire is not there...and i can't find a booster unless it's under my dash somewheres.
any help on this would be greatly appreciated
thanks in advance
BILLY
Username: Zdawg
Bismarck, North dakota United states
I need a wiring diagram for a 1995 chevy s-10 plz
Username: Zdawg
Aftermarket car stereo wiring diagram(pioneer)
Username: Sthrnrose
I have a 2002 grand am, The factory wiring harness has been cut, I am attempting to install the JVC headunit and, I believe I have the correct wiring guide for the factory wires, with that said, it still doesnt work, I will turn on, say "see you" and then shut off... I can eject and put in CD's but it will not hold power... I heard that other people had the same problem and their solution was simply that its the power lead/ACC. You have to run a wire from the fuse box using a fuse that only runs with the key in the ACC/on Position... Then reset the unit and it should be fine....
With that said, I have never had to do that, and dont have the SLIGHTEST idea where to start with that.... any suggestions, email me at christine.taylor@shaw.af.mil Thanks!!
Chris
Username: Zdawg
I am putting a new stereo(pioneer) in my chevy s10(1995) and i need a wiring diagram plz email me at zachshoops99@msn.com
Username: Brute_nm
Does anyone have the wire colors for a 99 Ford Escort please? You can email it to me at swderek@yahoo.com if it isn't too much trouble.
Thanks!
Derek
Username: Shefki_gadishi
Hello all,
Can anyone help me out, I'm trying to install new pioneer deh-4800-mp on a 1996 Ford Probe GT, any help will do.
Thanks.
Username: Ziggity
I need a factory wiring diagram for a 2002 civic ex (not sure if the ex matters). I just need to know which wires are which coming off the factory radio.
(Speakers and where to put a remote wire for an amp)
Username: Srparke
Can someone give me the original factory wiring diagram for a 1992 Dodge Caravan? A written list with the factory wire color and connection purpose would do. The factory wire colors don't match the new aftermarket unit's colors. The previous owner jacked the speaker wires up through a strange harness loop and I would like to install a new radio head unit direct to the factory wiring. Last install would crackle on bumps due to the jacked wiring and I'd rather have a direct splice.
Thanks much.
Username: Nickleass
Hey, i need a wiring diagram for my 1987 camaro, having troubles matching up the right wires to my new stereo.. thanks!
Username: Leew
Post Number: 1453
$50
Username: Nickleass
all i need is a copy of the diagram for the wiring harness...
Username: Leew
Post Number: 1515
Nicholas Harris
take it from here: btw(I included all three systems)
Click Me!
Please,let me know if it match to you!
regard,
Jennifer.
Username: Dongee
Hi everyone, i'm having some trouble installing a sony xplod cd player in a "2005 nissan almera s". CD player works fine wit the speakers but after in the installation the tail light fuse (which also connects with the dashboard light) fried. tried it a few times...same thing happens. i touched only the audio wirings from the back of the factory cd player. Can anyone help????? PLease!!!!
Username: Leew
Post Number: 1518
the illumination wire is not right connected!
Username: Dongee
Thanks Jennifer but the standard audio wirings does not have a cable for illumination. i've been searching for wiring diagrams to check that but can't find for that particular car on the net. 2005 Nissan Almera S. I still need Help!!!
Username: Leew
Post Number: 1531
well Don, then you have to get this:
http://cgi.ebay.com/NISSAN-Almera-N16-Series-Workshop-Manual-CD-2000-2005_W0QQit emZ230102086490QQcategoryZ72274QQrdZ1QQssPageNameZWD2VQQcmdZViewItem
cause I diged out all nissan(but USA and Japan models) and it's shows me the same: there is a illum. or dimming wire and it's connected to the light system.
Username: Dongee
Okay thanks Jennifer, the ebay item has already been sold, but i think i know which one is the illumination cable. U've been a great help!!! Once again Thank you
Username: Wolfeyes1987
I have a 1993 Ford Taurus and I'm trying to put a CD player in it, but I have no idea what wires are for what. Can someone please help me?
Username: Leew
Post Number: 1543
Chris Bower
Click here!
Enjoy!
Username: 81c3owner
looking for wiring specs for a 81 chevy corvette. I'm installing a radio, but someone cut the OEM wiring harness clean off. I bought a new Metra harness to replace it with, along with the clip in wiring harness that connects to the radio(in hopes that future owners never have to deal with this crap). Now i just need to know what the GM colors mean. Thanks, Kat
Username: The_image_dynamic
San Diego
Post Number: 631
Here you go Kathleen
Username: 81c3owner
thank you VERY MUCH brad.
Username: Power270
Looking for stereo wiring diagram for a 97 Toyota Tercel?
Please email to
power270@hotmail.com
Username: Hoomun
hi there i need help with wiring diagram of a Ford falcon Gli 1998.
thank u
Username: Zou95
Hi
I have a ford escort lx 1994, i removed the original car radio and i purchased a pioneer DEH27-MP, i have problem installing wires. for pioneer i have one yellow (to terminal), red (to electric terminal controlled by ignitionswitch),black (ground) to vehicle (metal) body, this is for the car radio but for the car harness i found a problem i have 1.blue wire ( i thoink it's for terminal, 2.red (ground this pin, 3.blue (IGN live), 4.red (illumination), 5.Nc, 6.ground, 7. electrical aerial) i have foun this diagram in internet for ford but i'm not so sure it's the same
what i have in the car is 2 reds , 2 blues and one thick balck , i don't know where to attac wires together can someone help me please
this is my e-mail zohirg@hotmail.com
thx
Username: Monkai
Please email to freshprinceoflbc@yahoo.com
Username: Badford77
I need a wiring diagram for a 98 expedition with premium sound and rear seat controls
Thanks
Username: Chooter87
2005 mitubishi lancer sterio wire diagram
Username: Skafreak898
Longview, Tx
Can i get the 2004 dodge neon stock cd player wiring diagram
Username: Schwarze
Brenham, TX U.S.
i need a wiring diagram for a dodge charger 06 please
Username: Critter53035
If somebody could help me out with the radio wiring diagram for a 1992 ford escort sedan, i would greatly appreciate it. Thank You
Adam Gutschenritter
Username: Buskirk26
Bangor, PA Unisted states
i need a wiring diagram for 1995 chevy cavalier
Username: Dkstr24
I have a 1996 pontiac grand AM and i hooked up the wires with the scoche wiring harness but have the yellow wire and dont know were to put it can you help me?
Username: Ryanh1921
i have a friend that tried to install a head unit in my 1990 toyota camry and accidently cut the harness wires from the old head unit and now i have the factory wires and the new head unit wires all hooked up. i just need help finding a diagram that shows what wires go to what factory wires.
email me @
ryanh1921@gmail.com
if u have any answers for me.
thnx
San Diego
Post Number: 1144
@ Brian Buskirk
@ Bobby Y
@ Ryan H -- email sent
Username: Buskirk26
hey brad thanks
Username: Blkwardog
Adel, Iowa Usa
Post Number: 129
brad can u get me one of those charts for and 85 accord at all? my h/u is coming tomoro so i gota figure wut im doin lol
San Diego
Post Number: 1222
No problemo
San Diego
Post Number: 1223
@ Adam Gutschenritter
Username: Akamigs
Post Number: 110
i need help wiring a head unit to my 2001 nissan altima. can you get me the chart? thanks for the help.
Username: Buskirk26
Post Number: 7
hey brad i have all the wiring hooked up and it has power, when i hit the power button to turn it on it will start to flicker and i cant do anything, would you know what the problem would be
Username: Da_3xp3r1m3n7
where can i find the wiring chart for the radio of a toyota tercel 92? does anyone know??
Username: Koaco
Columbus, Ohio USA
Just had to junk my 1995 VW Jetta and inherited a low-mileage 1994 Ford Taurus. Need to put the Jetta's radio in the Ford. Anybody know where I can get a wiring diagram for the radio in a 1994 Ford Taurus?
Username: Ncoll
Hi, I'm trying to wire up a new stereo to a UK 1993 Ford Escort however the colour coding of the stereo wires in the vehicle is totally different to everywhere I've found online. I've managed to figure out the speaker wires but I can't work out the others. they are:
red, brown, yellow, blue/yellow, brown/white and fat brown.
If anyone can help I'd be grateful
Username: Kurbz
Hi, i have a 1994 ford escort station wagon and i'm trying to install a 2005 clarion bd457mc
And i have tried installing using a few references from different sites but haven't managed so can someone help me out. Thanks.
Username: Spaguy
Need help on my 2000 Explorer Limited w/premium sound... There is an aftermarket deck in now but the subwoof in the rt cargo panel was never hooked back up.. Whats the location of the stock amp/amps? and colors of wires for the woofer?
Username: Spaguy
Anyone Here?
Username: Killswitchjd
Post Number: 646
1980 chevy malibu. thnks
Username: Wojopro
Summerville, SC
Post Number: 294
1978-85 Chevrolet Malibu Stereo Information
Constant 12V+ Orange
Switched 12V+ Yellow
Ground Black
Illumination Gray
Dimmer Brown
Antenna Trigger Pink
Antenna Right Front
Front Speakers 3 1/2" Dash
Left Front (+) Tan
Left Front (-) Gray
Right Front (+) Light Green
Right Front (-) Dark Green
Rear Speakers 6" x 9" Rear Deck
Left Rear (+) Brown
Left Rear (-) Yellow
Right Rear (+) Dark Blue
Right Rear (-) Light Blue
Username: Wojopro
Summerville, SC
Post Number: 295
Nate
http://www.the12volt.com/installbay/stereodetail/542.html
Username: Wojopro
Summerville, SC
Post Number: 296
DK
http://www.the12volt.com/installbay/stereodetail/843.html
Username: Wojopro
Summerville, SC
Post Number: 297
Andrew,
http://www.the12volt.com/installbay/stereodetail/922.html
Username: Wojopro
Summerville, SC
Post Number: 298
Peter Finch,
http://www.the12volt.com/installbay/stereodetail/2145.html
Post Number: 647
thanks stan
Username: Wojopro
Summerville, SC
Post Number: 302
NP
Username: Ezex007
Miami, Florida US
Hi, I just bought an old '93 honda civic, barely working but most of its parts still funcioning. The previous owner lived in a bad neighborhood so they car got broken into a couple of times and they stole the radio. I have about 10 cables of which I've already tried to find the speakers, at least two, so that I can make a direct connection to my mp3, so that at least I have some kind of music and radio. Could anyone help me decipher the cables? thanks
Username: Psyraz
I have a 94 Ford Thunderbird with Premium sound package and a OEM 10-disc cd changer in the trunk..
I've tried to follow the12volt guide for my car but I guess because of the premium sound package its wires are a different color for speakers?
Can anybody show me a diagram or something that will show me how to hook my new stereo up properly?
Facebook
Directory
