Fi 15" Q? BP Power?
Username: Jt212
Thinkin about getting a new fi Q 15 and saw you get upgrade with bp power, was wonderding how much the bp power would allow the sub to be pushed. sub rated at 1000w rms? thanks
Username: Killerzracing71
Fredericksburg, Virginia United states
Post Number: 1682
from what i read on the site the bp option add about 400- 500 rms o the coil not sure though im lookin at getting a 18"
Username: Jt212
what does the option dual 2 or dual 1 mean? that confuses me with what amp to buy.
Username: Bass_enjoyer
Post Number: 11
Those are the voice coil options. If you only plan on having one subwoofer, the dual two can be wired in parallel for a 1 ohm load, and the dual 1 ohm can be wired in series for a 2 ohm load. Find a good amp that does the power you want at either 1 or 2 ohms, and get the subwoofer voice coil options to match.
Username: Jt212
alright well i have been looking around and i really want to bump with either the Q or the BL. I have been hearing the Q is just for sound quality so i was thinking of getting the BL. But the Q has the bp power option so im suck on what will hit harder? Any help??
Post Number: 14
From what I know the BL will hit harder; it's more efficient and fully loaded can handle more power. It should still sound pretty good, too. The Q will sound better, and hit the *extreme* low notes better.
Hope that helps, someone will correct me if I am wrong. It all depends on what you are looking for. Sounds like the BL in your case.
Username: Jt212
yeah your right im thinking about the BL thanks for the help
