Powering 2 speakers and small sub on 1 amp???
Username: O0airjordan120o
MN US
Post Number: 152
so my friend is sellin his subs because he wants to go for Sq with 1 10 inch sub and amp his back speakers... he has a 2 channel 120 watt rms at 4 ohm amp. we were debating weather or not he could hook up the smaller sub and the back speakers of the one amp.. is it possible?
the sub is a single voice coil 4ohm
i was thinking maybe you could connect all the wires together and run the amp bridged
or
run the sub bridged... but have the speakers set up 2 channel.. if that makes sense.
could also run the speakers parrelell and hook up the sub to the other imputs.
Username: Press1
Yuba City, CA USA
Post Number: 261
The old hifonics series VII amps could be wired with the sub bridged and two satellite speakers in stereo. You just had to watch your ohm load.
I don't know of any other amps like that, but I don't see why it wouldn't work, as long as its bridgable.
Username: Insearchofbass
Post Number: 6840
Post Number: 6841
http://www.bcae1.com/trimodpd.htm
