Good idea o bad idea
Username: B3n07
Louisville, Ky USA
Post Number: 439
ok becuz i finally have the right power for my kickers why should i just stop there but shouldnt i get a new box think about getting a 2 cuft bo ported but not sure how good it will sound what do you all think????
Username: Nyyfan13
Fi SSD USA
Post Number: 6539
getting or building? dont even bother buying a prefab box.....
but sure why not try out a new box and see what happens....if you dont like it, then use the old box
Username: B3n07
Louisville, Ky USA
Post Number: 441
a shop arround here does custom build on boxs and i like there quality i just callem up tellem what i want and they build it there resonable and use good stuff on the boxs
Username: Insearchofbass
Post Number: 6788
should learn how to do it yourself then you can do it whenever you want....plus it will help if you want to customize other parts of your install
Username: Nd4spd18
Northwest PA
Post Number: 3421
Not everyone can build there own boxes even if they wanted to learn. Me for example. Being in college I've go noplace to work.
Username: B3n07
Louisville, Ky USA
Post Number: 443
well i would love to learn since i am tring to open or get into the cxaraudio business
