Battle of the batteries
Username: 420alldaylong
Post Number: 2763
Which one do you think is better?
Kinetik vs Odyssey
Username: Nd4spd18
Northwest PA
Post Number: 3457
Depends on what "better" is.
Equivalent models of those two brands will have about the same amount of power.
They both float at about the same voltage.
Odyssey batteries are built with toughness are the primary goal...... good for putting under the hood.
Kinetiks cost slightly less I think.
Username: Nd4spd18
Northwest PA
Post Number: 3458
Also a tip if your looking at batteries: Stinger batts are actually Odyssey batts with stinger labels, and they usually cost more..... just throwin that out there
Username: Frkkevin
Post Number: 3853
what about NSB? :-):-)
Post Number: 2767
Link please^^^^^^^^^^
Username: Frkkevin
Post Number: 3857
www.northstarbattery.com/
you might just google it to find more info :-)
Username: Joebruce
15 AQ HD3
Post Number: 1576
Jack before you get even more cocky than you already are,if you google NSB this is what it comes up with
http://www.google.com/search?hl=en&q=nsb&btnG=Search
Most people wont know what NSB stands for, so stfu Mr. Google First cuz im the sh*t!! You lil richey b*tch mommas boy!!
Username: Renegadesrun
Lafayette, IN US
Post Number: 984
The Odyssey releases faster than the Kinetik. Therefore, it would be slightly better in a comp application. Daily, you wouldnt know the difference.
IIRC.
Username: Frkkevin
Post Number: 3859
for one im not a "richy boy b!tch mommas boy" so don't go calling me out.. and i never said i knew everything.. was simply adding to the list but i don't even have to defend myself lmao.. this forums been falling apart for months due to people like you and the over-run of n00bs .. ecoustics is lucky a lot of the older members still post here and try to help
i simple said FOR MORE INFO GOOGLE IT .. cuz their website don't tell you anything about audio install uses..
so whats your beef?
Username: Bigmatt1986
Jacksonville, Florida U.S
Post Number: 24
BURNED!!!!!!!!
Username: Ctmike
Ct.
Post Number: 5353
i've always been curious, but what kind of system you have joey?
Username: Hdubb
Team Revolution
Post Number: 2689
the stingers do release power and charge faster which is great for comps. but honestly i think id run an agm deepcycle battery for daily. have more storage capacity but also take a good amount of time to fully charge. imo but odessy and kinetik are both good choices and im sure youd be happy with either
-apem
Post Number: 15486
nsb 90 is a beast. it would put both of the batteries you mentioned to shame. if you can make room to fit one under the hood the you are good to go. make sure you train it well.
Username: Rovin
4 10 Pioneer...
Post Number: 12396
GREAT THREAD !
kinetic has been the buzz lately but looking forward to seeing some more responses ....
Username: Frkkevin
Post Number: 3861
nsb 90 in the trunk FTW :-)
Username: Hdubb
Team Revolution
Post Number: 2690
some classes for comps limit bat size per catagory and or how many bats. the rage now is 16v charging systems.
Username: Nd4spd18
Northwest PA
Post Number: 3471
Northstar batteries are GREAT, for competition that is. They aren't meant to be used in vehicles, and aren't designed to stand up the environment under the hood of a car. They're great if mounted inside though.
Hunterw:
Odyssey and Stinger batteries are exactly the same thing in a slightly different case with different labels. One is not better than the other, they are the same battery.
Username: Hdubb
Team Revolution
Post Number: 2691
if i said they werent it was a error i know hey are they same as well as the tsunami bats same thing. dont mean to mis lead if it seemed if i was comparing two it was the kinetik and stinger.
Username: Nd4spd18
Northwest PA
Post Number: 3473
Oh my bad then, I read that wrong
Post Number: 2769
ctmike
At the moment Sundown SAZ-1500D and 2 10" kicker L7's(I know I know L7's sound like sh!t but hey they were cheap.)
