Alpine Type R in 1 cu. sealed box
Username: Dub_c
Post Number: 312
My question is will there be a sound difference in a 1.2 cu sealed or a 1.4 cu sealed OR EVEN!! a 1.6 cu sealed?
Thanks!
Username: Logan__tille
Team Revolution
Post Number: 8975
I dont think you will notice a difference from 1.2 to 1.4. But you will probably notice one from 1.2 to 1.6.
Username: Dub_c
Post Number: 313
So is this one of those "The bigger the better" I should go with either the 1.2 or just go for the 1.6?
Thanks again
Username: Adddisorder
West palm, Florida
Post Number: 5159
i dont know what is recommended for that sub but 1.4 sealed with polyfill should be good
Username: Rovin
4 10 Pioneer...
Post Number: 12291
got my spec sheet here - they rec .07-1.0 for it
i had mine in around close to 1cuft & it pounded ! ......
West palm, Florida
Post Number: 5163
rovin=type r master :-)
Username: Rovin
4 10 Pioneer...
Post Number: 12295
well i wouldnt call myself that but i did play around alot when i had mine .....
Username: Insearchofbass
Post Number: 6628
is this the 12?
Username: Dub_c
Post Number: 314
Yes its a 12" So which would be better 1.2 or 1.4 sealed? Thanks
Username: Dub_c
Post Number: 315
Still wonderin!
Post Number: 6667
do 1 cf and then stuff it if you need to
Post Number: 6668
1 cf net that is
Username: Dub_c
Post Number: 316
1 cf net? Whats that?
Palm Beach, Florida
Post Number: 5216
after displacment.
Username: Dub_c
Post Number: 317
I'm sorry your gonna have to bare with my dumb@ss but can you explain it for me! Thanks
Palm Beach, Florida
Post Number: 5220
when you put a speaker in a box the magnet and basket and stuff displaces airspace makeing the box smaller, you build it a tiny bit bigger to account for this. when all is said and done the total volume you are left with after the sub and port are in is the net.
Username: Dub_c
Post Number: 318
Ahhh ok then so lets say a 1.2 cu sealed box or maybe the 1.4 would be better I dont know how big the magnet is and how much basket will go in.
Palm Beach, Florida
Post Number: 5221
it will probably only displace .12-.15 i would just make the box 1.3 or something close to that and youll be fine. you can always put in some poly fill you might notice a very small change in sound with it maybe not. i liked it in one of my sealed boxes.
Palm Beach, Florida
Post Number: 5222
but if you really want that type r to shine port it.
Username: Dub_c
Post Number: 319
See I wish I knew all about porting, but I dont, someone told me to get a 2.0 cu sealed box and cut out a port, can this be done easily?
Palm Beach, Florida
Post Number: 5242
if you use an aero port search partsexpress.com for a 4" flared one.
Username: Dub_c
Post Number: 320
So you are sayin that if I get that 2.0 sealed box and get this:http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=260-403
it will work?
Username: Dub_c
Post Number: 321
Still need your help!
Post Number: 6731
dont get that port its not what hes talking about
Username: Dub_c
Post Number: 323
Can someone tell me which one he could be talking about then.
Post Number: 6743
well I found the port you need BUT one 4 inch aero is NOT anywhere near enough you would need two three inch aero ports
http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=268-350
Post Number: 6744
in a 2 cubic feet net box
Username: Dub_c
Post Number: 325
Ok so I would need a 2 cu net box plus 2 aero ports? Seems a lil too much.
Post Number: 6750
trust me I told someone one four inch wasnt enough and they didnt believe me now they have port noise....check linearteam thats what I did its never failed to steer me right when it comes to port size needed two three inch ports is just enough for a 32 hz port tune on 500 rms
Post Number: 6755
but you dont have to go with aero ports at all you can do a slot port or use pvc for ports
Username: Dub_c
Post Number: 327
Wondering, is there any place like wooferetc or whatever that have a pre made ported box that will work with a type r?
Post Number: 6772
pre made boxes are usually tuned too high and dont sound good and if not used with a subsonic to protect the sub it can be damaged ....making your own is the best bet for ported
Post Number: 6773
oh and if they are tuned low enough they probably wont have enough port area which could also damage a sub
Username: Dub_c
Post Number: 329
hhhmmm....
