Help help help
Username: Mike17362
Durham, Nc Usa
Post Number: 252
whats going on im looking at getting 2 sundown 1500s i need a 15 to run on each amp that will be loud clear and low im tunning at 28hz
what opions?
Username: Kyle_lowe
Post Number: 464
re sx
Username: Mike17362
Durham, Nc Usa
Post Number: 255
any others
Username: Snarl2004
Audioque 12 SD2.5s, Earthquake P...
Post Number: 1755
fi.q with all option for more sq or fi.bl with all options for more sql
q will sound better and both setups will sound great
Username: Kyle_lowe
Post Number: 465
many others, i just want a sx so that is what i said
fi bl
dd3515
aa havoc
cystal compx
Username: Mike17362
Durham, Nc Usa
Post Number: 256
lol how much for the sx
Username: Kyle_lowe
Post Number: 466
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=4915&C FID=6463002&CFTOKEN=38834d725510a5-AB15C9ED-1422-7C6E-501BCFBCC62CC8E5
your better off to find a local dealer though
Username: Kyle_lowe
Post Number: 467
or look to buy used
Username: Mike17362
Durham, Nc Usa
Post Number: 257
oh ok but are these that you have name my only/best options wherer can i find the compx at?
Username: Kyle_lowe
Post Number: 468
no, there are so many other good options, i only named a few
crystal dealer list http://www.crystalmobilesound.com/dealers.htm
Username: Loudon
Post Number: 1810
rd alpha
Username: Mike17362
Durham, Nc Usa
Post Number: 258
are you sure that the sundown is going to work on a alpha?
Username: Loudon
Post Number: 1811
thats what im running pal
doing a 145 db drag
4.0 cu ft 32hz
Username: Mike17362
Durham, Nc Usa
Post Number: 259
oh that is whats up how much for that sub?
will a mag do? will it be lowder than a w7
to get off the subject right fast with sub is better the mag 15 or the 05xx 15 im thinking the xxx?
Username: Nd4spd18
Northwest PA
Post Number: 3408
Fi Q or old RE XXX if your going to tune that low
Username: Mike17362
Durham, Nc Usa
Post Number: 260
will a sigle sx or a sigle mag be louder than w7 on a 500watt jl
