Deadenin my roof (It needs it :-))
Username: Southernrebel
Monroe, Louisiana 2 DD3515s, 1...
Post Number: 5361
Well, I finally got around to deadening my roof today. I ended up running out of Peel-n-Seal, but I got alot done.
Cleaned the roof off w/ acetone.
The first layer. It was kinda cool today and I didnt have a heat gun, so used a hair dryer. Just heated it up until it had some shine to it and rolled it on.
Got 3 layers on the back half of the roof, started on the second layer on the front half and ran out.
I'm going to do a total of 4 layers in the places that flex bad and 3 in the places w/ less flex.
More pics and results (by ear) tomorrow!
Username: Bernymac
BME
Post Number: 3353
Nice. I gotta start on mines. I hate hearing rattles :-).
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 12997
sh!t I went to Lowes looking for this stuff..where did u get it??
Username: Extrmndor3
Post Number: 6995
yeah where and how much for how many??
Username: Frkkevin
Post Number: 3791
its with the roofing materials ... good stuff .. hairdryers make it easy to install as well :-)
Username: Jkidder
Gunshine , State Flawda
Post Number: 2251
roofing section. i did my whole car with it. pretty sweet just takes a while to apply. and peels a bit on corners
Post Number: 6996
how much for how many sq???
Post Number: 5362
Like Kevin said, its in the roofing section. I bout the last 2 rolls Lowes in Monroe had. Going to check at Home Depot for more tomorrow.
I got it for ~$14 for a 6"x25' roll.
Not hard to install, just takes time.
Post Number: 6997
did you used all the peel and seal?? like all all that you used on you roof on your pics all the 2 rolls in there???
Username: Tremor1127
Fi
Post Number: 2349
my guess is the last pic was two complete rolls.
Username: Naledge503
Http://com4.runboard.c...
Post Number: 2061
He said that he ran out of peel and seal. And got 3 layers on the back half of the roof and started on the 2nd layer on the front part of the roof.
Post Number: 5363
Yep, I ran out. It went farther than I thought it would though. I'm going to get another roll or 2 tomorrow.
Username: Mendonmafia
Post Number: 426
i wish they had that stuff im my home depots
Post Number: 5365
They should...its a VERY common roofing supply.
Post Number: 5366
Ask the for 'aluminum backed flashing'
A pic is worth 1000 posts!!
Post Number: 10565
When I was into roofing it was called "flash burn". Some kind of substantial heat was needed to "set" the adhesive, (tar).
Username: Safe_cracker
Chicago, IL US
Post Number: 3643
I used a propane torch on mine has yet to come off! Polo..
Username: Frkkevin
Post Number: 3804
i just use a basic hairdryer.. that heats it up plenty.. leaving your car out in the sun also helps :-)
Username: Rovin
4 10 Pioneer...
Post Number: 12360
nice !
0.3 DBs gain perhaps ? ......
Username: Bernymac
BME
Post Number: 3363
I plan on using it on my floor and some other stuff for the roof :-).
