New member Username: TsenfwPost Number: 1 Registered: Oct-07 | You guys are probably sick of questions but I need some help. Got a great deal on an odd sub. Audiobahn ALUM10Q 10". It's a dual 6ohm voice coil with 800watt RMS rating (probably overated) and 1600watt max. I need a budget amp that will power 1 of these in a bandpass or sealed box in a trunk. Possibly 2 eventually if one 10" won't bump enough. So far I've been lookin at these refurbished amps: Kenwood excelon KAC-X812D: http://www.crutchfield.com/S-kRILJsXZpcX/App/Product/Item/Main.aspx?g=120&i=113K ACX812&tp=115 Infinity Reference 611a: http://www.pixmania.co.uk/uk/uk/504522/art/infinity/ref611a-subwoofer-amplifi.ht ml What do you guys think of these? If not good, any recommendations for $200 or under shipped? Doing this on a budget! Would 1 10" be decent at these levels or do you guys think I'll have to resort to two? |
Platinum Member Username: Rovin4 10 Pioneer... Post Number: 12331 Registered: Jul-05 | only u will know wah tlevel of ould is good enough 4u u should look for some kicker refurbed amps as well ..... |
New member Username: TsenfwPost Number: 2 Registered: Oct-07 | Oh, I was asking for advice on which brands are good and true to their ratings. Refurbs are a good idea, thanks for the advice. I wound up buying a Directed d2400 refurbished. Funny you mention the kicker, I almost got the kicker 750 refurbished but I saw that it wouldn't run at 1ohm if I wanted to run 2 of these wierd 6 ohm DVC subs. I'll see if this Directed does anywhere near it's advertised 800watt RMS @ 2ohm |
