New member Username: AufdeHartford, Wi USA Post Number: 1 Registered: Oct-07 | I've never made a box for anything before and have done some research, I want to see if I'm on the right track. What I have so far are some dimensions: One of these for each sub: 12 x 8.46 x 16.9 comes out to about 1 cubic foot(I haven't calculated the volume of the sub yet and I will change my box size accordingly). Then for the vent: Diameter:1.935 inches Length:3 inches Tuning frequency: 40 htz I found the box size by using a ratio I found (.7 x 1 x 1.4) that is supposed to produce the best results. And I used a calculator (http://www.ajdesigner.com/phpsubwoofervented/port_length_equation_fb.php) to find the vent dimensions. Let me know what you guys think and I don't mind constructive criticism(I'm not gonna kill myself if you guys think I'm stupid), and thanks in advance for the help. |
Platinum Member Username: Rovin4 10 Pioneer... Post Number: 12273 Registered: Jul-05 | which sub uses 1cuft ported & y r u tuning it so high ? ...... |
New member Username: AufdeHartford, Wi USA Post Number: 2 Registered: Oct-07 | "which sub uses 1cuft ported" Idk what that meens, I've never done this before...I don't really know what I'm doing One site said that 40 htz was a common tuning frequency. |
Platinum Member Username: Rovin4 10 Pioneer... Post Number: 12274 Registered: Jul-05 | post a link to ur sub 40hz is more like for pure loudness & u lose alot of musical quality especially for daily driving .... |
New member Username: AufdeHartford, Wi USA Post Number: 3 Registered: Oct-07 | http://www.xplodsony.com/ this is the closest I can get to a "link" to my subs...the model number is XS-L1037 and I can't find anything for them anywhere. Sony must have taken them off of their site for some reason. |
Gold Member Username: JkidderGunshine , State Flawda Post Number: 2092 Registered: Nov-05 | |
Platinum Member Username: Rovin4 10 Pioneer... Post Number: 12275 Registered: Jul-05 | cant find any info too so u may have to go by generic box volumes on this occasion if u got a 10" then most 10s use 1.5-1.7cuft 12" then 2-2.5cuft http://www.carstereo.com/help/Articles.cfm?id=31 & http://www.the12volt.com/caraudio/boxcalcs.asp tune below 35hz for more quality & above 35-40hz for more loudness with less quality ..... |
Platinum Member Username: Rovin4 10 Pioneer... Post Number: 12276 Registered: Jul-05 | oh & if pipe porting which i suggest since ur new then go with a 4" pvc pipe or aeroports ..... |
New member Username: AufdeHartford, Wi USA Post Number: 4 Registered: Oct-07 | Yeah, I have 10's. Is the 1.5-1.7 ft^3 the box volume without the sub in it? Or would I have to add the sub volume to 1.5 ft^3 to get the box dimensions? |
Gold Member Username: Joebruce15 AQ HD3 Post Number: 1464 Registered: May-04 | http://www.subwoofertools.com/forum/ported-box.asp |
Platinum Member Username: Rovin4 10 Pioneer... Post Number: 12281 Registered: Jul-05 | those cuft i listed are after sub & port displacements ...... |
