180 amp alternator
Username: Circa09skater
Post Number: 48
if i get a 180 amp alternator from iraggi would i have to do a big 3 or will the stock wiring be good enough?
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 12832
yes...even with a stock alt..I would recommend doing the big 3
Username: Tremor1127
Fi
Post Number: 2269
yep, do it.
the extra current has to be able to flow through the wire. and it may not, causing the alt to squeeze out less than designed amount of amperage...
Username: Skibum12189
Cleveland
Post Number: 1676
you'd be choking the alternator if you didn't do the big 3....the current wiring is probably sufficient for just the stock alt
