Like
Need help on head unit
Username: Jtinordi77
How much does the head unit really matter in the sound quality of your subs? ANd if it does could i get a good one for about 60 bucks?
Username: Dkchillin
Vermont
Post Number: 484
My first reaction would be "it matters to a point", followed by "no you can't". However, if you have low end subs then the HU really isn't going to make much of a difference amd depending on your setup one HU might sound the same as another to you while having very different sound qualities. For most low to mid-range subs the amp is going to be marginally more important than the HU. What are you running (or looking to run) in terms of subs amp and HU?
Facebook
Directory
