BBE - Pioneer HU
Username: Nyyfan13
Fi SSD USA
Post Number: 5936
i showed up for my class an hour early today so i decided to sit in my car play with the HU for about 30 minutes....first time i have done it since i got my stuff installed. searching around i found this BBE feature. didnt know what it was so i turned it on cause it was off. it made it louder and cleaner it sounded like. not sure if it should be on or not so i searched for it on this site and read it shuold be on. chad and jexx both stated to have it on. so before i keep it on, i just wanted to make sure i was correct in assuming to have it on?.....thanks
Username: Mike11202
Sewell, NJ US
Post Number: 975
Yeah I usually keep mine at 0, it sounds great
Username: Mike11202
Sewell, NJ US
Post Number: 976
Also go to settings by clicking and holding the joystick thing for 5 seconds, it gives you start up options. Set the Calibration to "low" instead of high.
Username: Nyyfan13
Fi SSD USA
Post Number: 5938
word....thanks mike
Username: Mike11202
Sewell, NJ US
Post Number: 978
do you have aftermarket speakers?
Username: Nyyfan13
Fi SSD USA
Post Number: 5940
yessir
Crystal Cpe 60s 6.5" Component with 1" Silk Tweeter
Username: Mike11202
Sewell, NJ US
Post Number: 979
Yeah you have the 780MP? I messed with the EQ and it makes a night and day difference on the highs
SOUND SPLINTER RL-S ON...
Post Number: 15009
i guess you want a second opinion. :-(
Username: Nyyfan13
Fi SSD USA
Post Number: 5942
7800 not 780 premier. ill go play with it tomorrow and let you know how it sounds afterwards. thanks again bud
Username: Nyyfan13
Fi SSD USA
Post Number: 5943
not second opinion chad, i wanted clarifacation. in your post it said that Mo told you to do it and nothing more basically. i wanted clarification and know what it did....sorry chad
Username: Mike11202
Sewell, NJ US
Post Number: 981
yeah same thing.. set the first about 4-5 bars to 0 and the rest to +5
let me know how that works for you
Username: Nyyfan13
Fi SSD USA
Post Number: 5945
alrite bud ill do that tomorrow. thanks
Username: Rovin
4 10 Pioneer...
Post Number: 12092
for some reason i dont care to use the BBE on my 860....
Username: Nyyfan13
Fi SSD USA
Post Number: 5946
whys that rovin? when i used mine for the quick minute or 2 it sounded better but i turned it off cause i wasnt sure wat it was exactly so i didnt wanna screw things up....
Username: Rovin
4 10 Pioneer...
Post Number: 12094
well IMO i just like natural sounds off a HU without the need to process or enhance anything ...on my deck pretty everything is set almost factory except a slight rise in tweeter & a sub high pass of 63hz i think ...no real need for to play around with anything else since my deck has quite good sq to it ....
Username: Mike11202
Sewell, NJ US
Post Number: 984
yea i love what the BBE processing does on the 780 makes it sound a lot better IMO
Username: Suleman36
Post Number: 4269
When i had my 860 HU, i didnt need the BBE feature but when i changed to the 780mp i definetly used it at level 1. It made a night and day differance in my case.
Username: Evoixmr
Post Number: 84
Just got a 880 with stock speakers and I keep the BBE on at 0 and it sounds badazz. I had my dad listen to it and he thought I installed my subs already. lmao
Username: Jtown
Post Number: 299
I have a pretty basic/older pioneer and I have an option of 1-3 for BBE, and I keep it at 3, but the subwoofer low because of the difference it makes in any song.
but i also have another option for the bass engine where I can set it at a spec fq, like 80hz, 120hz, etc. where should that be set?
Username: Mike11202
Sewell, NJ US
Post Number: 985
well you mean crossover freq? i would set that at 80hz
Username: Nyyfan13
Fi SSD USA
Post Number: 5949
"Also go to settings by clicking and holding the joystick thing for 5 seconds, it gives you start up options. Set the Calibration to "low" instead of high."
i turned the BBE on and set it at 0 and it sounds good. but i held in the joystick for 5+ seconds but nothing happened....it just acted like i hit it once and gave me menus like normal....
Post Number: 15021
did you read what the BBE does in the user's manual yanks. please read or google stuff before you post man. lol.
Username: Nyyfan13
Fi SSD USA
Post Number: 5950
i lost my manual.....:-(
and i searched for it just wanted some clarification.....damn, sorry chad :-(
Username: Goodie_goop
Mid town, Texas U.S.
Post Number: 753
http://www.bbesound.com/technologies/BBE_HDS/
Username: Mike11202
Sewell, NJ US
Post Number: 987
the joystick on the headunit not the remote. make sure your head unit is OFF, then it lets you change time and settings ect. thats where the calibration is
Username: Nyyfan13
Fi SSD USA
Post Number: 5951
gotcha...thanks for that mike and goodie
Username: Mike11202
Sewell, NJ US
Post Number: 990
no problem man.. did you try the EQ?
Username: Nyyfan13
Fi SSD USA
Post Number: 5953
nah i didnt really get the chance to play with it. i didnt have time today to do much. ima do it tomorrow tho for sure and let you know how everything goes
Username: Tatonka
Post Number: 805
Where at is the BBE feature? I need to try it out.
Username: Nyyfan13
Fi SSD USA
Post Number: 5955
hit the joystick, go to audio, scroll around in there and you cant miss it
Username: Mike11202
Sewell, NJ US
Post Number: 1005
here u go yanks
https://www.ecoustics.com/electronics/forum/car-audio/384983.html
Username: Nyyfan13
Fi SSD USA
Post Number: 5963
hats off to mike.....thats awesome bud, thanks
mike ftw
