My Custom Box
Username: Sb052287
Dallas, Texas USA
Post Number: 38
I want to design a box that will be in my trunk and have the port traveling into the cab of my car through the board behind the rear seat... does anyone know a site or if there is a name for this type of box?
Username: Sb052287
Dallas, Texas USA
Post Number: 39
can someone please help me?
SOUND SPLINTER RL-S ON...
Post Number: 14675
just make a ported box with the port extending to the board you are talking about.
A pic is worth 1000 posts!!
Post Number: 8970
In trucks ppl use a blow through design, using the truck's bed capacity as room for the box and ported into the cab.
http://vids.myspace.com/index.cfm?fuseaction=vids.individual&VideoID=998621
Not sure if it helps.
Username: Sb052287
Dallas, Texas USA
Post Number: 40
CAN I USE A CIRCULAR PORT WITH A SQUARE SUBWOOFER?
Username: Thumpinwith8s
2 RE8s, 300 watt Jense..., 133.3db@49hz!!
Post Number: 549
a circular PORT ....yes, A circular hole for the subwoofer...no
Username: Rovin
4 10 Pioneer...
Post Number: 11909
well then just simply design a box with a slanted front firing into the cabin ......
Username: Sb052287
Dallas, Texas USA
Post Number: 41
ITS A CAR NOT A TRUCK?
Username: Denali_on_22s
Im just light up my......
Post Number: 2556
STOP TYPING IN CAPS.
