Ot:: My First Box
Username: Kpa2727
Post Number: 435
props to dave aka reckless on the designs. i struggled alot with small cracks in like 3 places.i gorrila glued and loctited them so it should be fine. but heres how it went, my first ever attempt.
Username: Tremor1127
Team Fi Car Audio [:-]
Post Number: 2066
not bad dude. gorilla glue works great if you happen to have big cracks.
i said big cracks.
anyway, looks great and the circle doesnt look like a 3rd grader did it either. :-)
Username: Kpa2727
Post Number: 436
lol thanks , yea once glue dries i'll sand it all smooth. the thing that made me mad was i built the box upside down reversed as opposed to the first pic which was pre fit test. i was like wht the ahhh f##k. then reversed the box build, now tomm i replace all rcas in the car. due to dry rot then wire in a new stereo amp then by sat or mon my highfonics 1606d should arive. then the type - r goes in, then i party and pick out a grave cause by then in this heat i'll be dead. an tomm thier callin for nearly 100 percent humidity. at almost a 100 degrees, plus i have to finish my amp rack for under the seat and the hifonics in the trunk, going to get intresting.
Username: Rovin
4 10 Pioneer...
Post Number: 11890
not bad 4 a newb - i hope u used more screws after u took those pix ....
Username: Kpa2727
Post Number: 438
yes i did about 15 or so more lol.
Username: Drivingreckless
DD 9515f, 148.2 db Mov...
Post Number: 3871
dude our box looks better then mine :-)
VENGEFUL SPIRIT
Post Number: 14647
nice box. looks very complicating to make. mad props man.
Username: Th3pwn3r
Post Number:...
Post Number: 3994
Looks good man.Nice job.
Username: Insearchofbass
Post Number: 6025
very good first box
Username: Kpa2727
Post Number: 442
thanks guys, i try to be as skilled as possible. in my eyes it won't be perfect till i sand. not sure if i'll carpet or use a wood grain design.
Username: Andrew571
Post Number: 1101
the entrance to the port (inside the box against wall)
looks a bit smaller than the exit...? maybe camera angle
very nice work tho. Good circle :P
Username: Kpa2727
Post Number: 445
this should help ya see thier fine, but thanks andrizzle.
A pic is worth 1000 posts!!
Post Number: 8933
Nice job man. Have a cold one for me lol.
"thanks guys, i try to be as skilled as possible. in my eyes it won't be perfect till i sand. not sure if i'll carpet or use a wood grain design."
Wood grain design? As in paint? J/C.
Username: Imalik
SD2.5......ED9.1=Boom, New Jersey Lord Protect...
Post Number: 510
Congrats looks good..
Username: Kpa2727
Post Number: 446
i was kind of thinkin of that or the stuff they put on cabinets. or even covering it with batting and fake suede give it a real plush look.
Username: Kpa2727
Post Number: 447
Username: Kpa2727
Post Number: 448
effin double crap. Upload
