Sub placement vs. port placement
Username: Theweasel
2 12 FI SSD, Colorado U.S. of A
Post Number: 944
i am deciding how to mount my 2 12" ssd's and 2 4" aeroports on my box. it is in a trunk and here are my 4 options:
1) subs facing back, ports on drivers side
2) subs facing back, one port facing back one on drivers side
3)sub on each side of box facing to the side, ports facing back
4)subs facing back, port on each side
which would be best?
Username: Kaprese
Walstonburg, NC USA
Post Number: 312
I would choose either 2 or 4 but I have always had the impression that it would have better output with subs facing back and ports facing back (same direction)
Username: Theweasel
Post Number: 945
bump
Username: Theweasel
Post Number: 947
i just got all my cuts done so i need to know
Username: Jblanford
Post Number: 2086
you should get 1 or even 2 more ports ...
and why don't you tell us your car ? trunk car ? suv ? truck ?
Username: Theweasel
Post Number: 949
trunk, acura tl 3.2
can't really fit another port, and i can't find one long enough. needs to be 21" long for 3 ports
Username: Jblanford
Post Number: 2090
ok...go subs back ports to the driver side
Username: Th3pwn3r
Post Number:...
Post Number: 3991
Ok.Try all of the above and find out what works best through actual testing.Whether that's SQ,SPL or whatever.
Username: Theweasel
Post Number: 950
yeah i'd try that but i don't really think by box will be air tight with numerous 6" holes all over the place.
Username: Insearchofbass
Post Number: 6018
prob cant but can you do external ports
Username: B3n07
Louisville, Ky USA
Post Number: 106
well dont you like listing to your music through swiss chesse
Username: The_image_dynamic
San Diego
Post Number: 2600
subs down, ports down -- it's what all the cool kids do.
Post Number: 6020
I wanna do that but Im afraid the sub would sag after a while
San Diego
Post Number: 2601
Sean I figured that a person such as yourself who is so tight with the admin would know that we have a couple real nifty features called "edit" and "delete". Look into it sparky.
Post Number: 6021
Brad its over lets move past that now
San Diego
Post Number: 2603
Fair enough.
Post Number: 6023
thank you
