Help with my newest purchase...
Username: Mgbcs
Maple Grove, Minnesota
Post Number: 1470
I just purchased two RL-i 8" DVC 4-ohm subs. I am thinking about getting a Rockford t5001bd amp to power it unless someone has a better idea. Also, what would you guys recommend for a box? I can follow what's on the site, but I would be interested to know any other opinions as far as size and tuning. I was a good SQL ported box. Thanks guys
Username: Theweasel
2 12 FI SSD, Colorado U.S. of A
Post Number: 931
with companies like that they usually know what box to use
Username: The_image_dynamic
San Diego
Post Number: 2570
WTF my post went away. Well what I basically said is put them in a divided sealed box with .6 cubes for each. Also that RF amp only will put out 250 per which is not enough. Get this amp and wire the subs for a 1 ohm total load.
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=373
Username: Mgbcs
Post Number: 1471
That amp puts out over 1000RMS on all the birth sheets I have seen. That is why I am considering it.
Username: Mgbcs
Post Number: 1472
So, you think go with a sealed rather than ported?
Username: Ctmike
Ct.
Post Number: 4883
interested in a sundown sae1000d? 1000wrms @ 1ohm. bnib, still under warranty, never seen power. $280 shipped.
sorry for the thread dump, just saw the oppurtunity.
Username: Theweasel
Post Number: 937
that's a good deal^^^
i'd snatch it
San Diego
Post Number: 2571
Yes go .6 sealed, those 8's will blow your mind. Buy Mike's Sundown, it would be perfect.
VENGEFUL SPIRIT
Post Number: 14616
lol you said blow.
anyways ben, congrats on a fine purchase. i think you will be very happy.
San Diego
Post Number: 2573
And Ryan said snatch
VENGEFUL SPIRIT
Post Number: 14620
lol i didn't see that.
Username: Mgbcs
Post Number: 1474
Mike...I don't know what to tell you at the moment. I don't know if I want to spend $280 for an amp on this setup. I am trying to go a little cheaper, and that is why I picked out the Rockford. I will deffinitely keep that in mind. I know it's a great amp and great deal, I just don't know yet. Thanks man.
Anyone else have an opinion? Especially on the box? (Thanks Brad, BTW)
VENGEFUL SPIRIT
Post Number: 14622
0.5 cu ft net volume sealed
0.3 cu ft net volume vented, Fb = 35 Hz
straight from their site. its weird how the ported box is smaller than the sealed. but thats what mike at soundsplinter wants so i would do it like that.
Username: Mgbcs
Post Number: 1476
OK. Well I will go by the site then. Should I go sealed or ported then? I want SQL and brad suggested sealed, which suppised me.
VENGEFUL SPIRIT
Post Number: 14623
go sealed man. the output will surprise you.
the cool thing about it is if you don't like it sealed, you can make a hole and put a single aeroport in there. since the sealed box and the ported box are similiar. the port will take up some space in the box so your displacement will drop.
Username: Mgbcs
Post Number: 1477
Good deal. With these subs then, output is pretty similar sealed and ported? Impressive.
Username: Denali_on_22s
Im just light up my......
Post Number: 2543
well ported will probnbaly be louder... then agin im drunk so who knos
Username: 420alldaylong
Post Number: 2390
That RF T5001bd is a good amp sh!t all the RF T series are good.
Username: Evoixmr
OK, quick noob quest. Thinkin on runnin 2 FI Q's 12", off 2 Memphis 1000w amps, but might require alt upgrade, since I will be runnin the rest of the setup off a memphis a/b amp. 3 amps total!!! Is there a more efficient setup to get sick sql?
Username: Mgbcs
Post Number: 1478
Bump for final opinions...
Username: Adam_s
Post Number: 1774
I say port them.
Username: Mgbcs
Post Number: 1479
I am kinda leaning towards that only because I want to make sure they are loud enough.
Username: Oneracistguy
TWO EGG, FL USA
Post Number: 828
i installed 2 rl-i 8s in a truck go ported sounds amazing and i put em on an orion 600d 300rms for each and they shined
