Is this my best choice
i have about $$350 to spend on subs and i want something that is gonna
be good and loud....i was thinking about 3 alpine type r 10's anyone
have ane suggestions on these subs or and other subs that i can get in
this price range???
thank you
Bin Laden
You can get 3 Adire Shiva 12's for $125 each. They move a ton of air and get loud as hell. They sound good too for the money. Much better than your Alpine type R 10's. I hope this helps.
www.adireaudio.com
thanks bin laden i might do that..what kind of box should i get and how big of an amp... like to get the amp for around $$$300
Bin Laden
For the Shiva's a sealed box would be best. You can buy a triple 12 sealed box at sounddomain.com. For the Shiva's you don't need much power but Adire says it can handle about 350 watts per sub. If it were up to me I would buy the JBL Power Valve BP 1200.1 mono sub amp on sounddomain.com it is on sale for $300 and it puts out 600 watts. That would be 200 watts on each Shiva 12 and that would sound very nice.
