Silver Member Username: TatonkaPost Number: 552 Registered: Mar-07 | D@MN YOU OGLE! First, you false advertised this 3/0 wire as 2/0. Now im out in 100 degree weather spening 2 hours just trying to cut all the pieces! lmao just messing with you man, but it really sucks when you don't have the proper equiptment to cut such large wire. Other than that....ogleisthebest |
Gold Member Username: OglejustPost Number: 2337 Registered: Aug-06 | lol thanx man... btw u arent the only 1 out in the heat, im workin my azz off buildin chaunceys box. good luck man |
Silver Member Username: TatonkaPost Number: 554 Registered: Mar-07 | Thanks man, Im out in the heat wiring up a battery. plus doing big 3, plus buidling an amp mount. I think I'm just gonna keep the amp sitting in the backseat floorboard. |
Silver Member Username: Thumpinwith8s2 RE8s, 300 watt Jense..., 133.3db@49hz!! Post Number: 379 Registered: Jun-07 | at least ya'll are in the heat doing something you like, I was in the heat today MOWING THE LAWN at work....sucked, but I got to go home 2hrs early...woot? |
Gold Member Username: OglejustPost Number: 2339 Registered: Aug-06 | ^^^ did u cry? |
Gold Member Username: Nyyfan13Fi SSD USA Post Number: 5497 Registered: Jul-06 | last year i worked 15 hours straight outside in a parking lot starting at 11 am until 3am or so....during the day it got up to 105degrees with a heat index of around 115-120....getting paid 7.50 an hor praking lot attendant FTMFL |
Gold Member Username: Th3pwn3rPost Number:... Post Number: 3662 Registered: Jul-06 | "lol thanx man... btw u arent the only 1 out in the heat, im workin my azz off buildin chaunceys box. good luck man" It's not even hot here in Illinois... |
Gold Member Username: Adam_sPost Number: 1662 Registered: Aug-04 | Same here in Wisconsin it is actually a little chilly if you have shorts and a t-shirt on. I would say 60s-70s. |
Silver Member Username: Big_edge_headMilwaukee, Wisconsin USA Post Number: 315 Registered: Mar-07 | what part of wisconsin do u live in. and i was out workin my azz of mounting my 2 amps on the back of my seats. after 2 days of work i am very happy. it took so long cause i had to wire up a whole new amp and run a bunch of speaker wire thru the doors. i mounted everything under the seat carpeting and it looks so good no wires are showing. too bad i dont have a camera |
Gold Member Username: The_image_dynamicSan Diego Post Number: 2345 Registered: Dec-06 | The fact remains that summer sucks fucking ass. |
Silver Member Username: Big_edge_headMilwaukee, Wisconsin USA Post Number: 317 Registered: Mar-07 | no way i hate the snow and the cold. i cant even do anything to my car. i hooked up an amp when it was 20 degrees out last winter and that really sucked way worse than working in 80-90 degree weather. i couldnt even move my fingers to do anything it was so cold. and in the winter your system dosent perform as good cause everything is 0 degrees and then more rattles appear. |
