Silver Member Username: Dakangofkrunk16Post Number: 771 Registered: May-07 | JL just came out with a Slash V2 series amp http://mobile.jlaudio.com/products_amps_pages.php?page_id=221 LOOKS TO BE VERY PROMISING R.I.P.S. Systema¢ - read the info on that, pretty cool if u ask me.. I know u all thing JL is over priced, but they do make great amps |
Gold Member Username: Th3pwn3rPost Number:... Post Number: 3629 Registered: Jul-06 | Capable of running on 11 volts is nice for people with crappy charging. |
Gold Member Username: HdubbFarmington, Nm Usa Post Number: 2268 Registered: Nov-04 | but cant gain any at higher voltage. =( |
Gold Member Username: Logan__tilleI walk around like I g..., Yea thats ab... Half a brick... Post Number: 8525 Registered: Feb-06 | Pretty. |
Platinum Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 12574 Registered: Jul-05 | i WANT SUM!!! |
Gold Member Username: 420alldaylongPost Number: 2263 Registered: Sep-06 | The same expensive sh!t |
Silver Member Username: Mike11202Sewell, NJ US Post Number: 819 Registered: Nov-06 | ![]() |
Gold Member Username: Tremor1127Team Fi Car Audio [:-] Post Number: 1910 Registered: Aug-06 | they make good stuff for being WAY mainstream... |
Silver Member Username: BasssquaredKansas Post Number: 986 Registered: Nov-06 | mainstream is not always bad |
Platinum Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 12576 Registered: Jul-05 | mainstream or not...its a bad azz amp |
Silver Member Username: BasssquaredKansas Post Number: 987 Registered: Nov-06 | with a badass price |
Platinum Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 12577 Registered: Jul-05 | save now shine laidher |
Silver Member Username: BasssquaredKansas Post Number: 988 Registered: Nov-06 | spend now and twinkle |
Silver Member Username: Mike11202Sewell, NJ US Post Number: 820 Registered: Nov-06 | ill have a suprise for u guys in a bit.. once i find a usb cable ![]() |
Gold Member Username: SouthernrebelMonroe, Louisiana DD 9515d~~]... Post Number: 5085 Registered: Mar-04 | ummm....the only difference i see is that JL just rebadged them "v2". WTF? |
Gold Member Username: 420alldaylongPost Number: 2267 Registered: Sep-06 | I heard they were making a bigger mono amp than 1000 watts guess not. |
Gold Member Username: Th3pwn3rPost Number:... Post Number: 3631 Registered: Jul-06 | Can you guys believe I didn't talk sh1t to Dru?I don't even think I can ![]() |
Gold Member Username: Extrmndor3IF U HEAR ME... crazydbs.com Post Number: 6046 Registered: Feb-06 | WOW THOSE ARE PRETTY SOLID ONES JUZZ SEE HOW THEIR D CLASS HAVE SOME THINGS FROM A/B CLASS AMPS PLUS HEY THEY HAVE SOME GOOD AZZ CAPACITANCE BANK.... I THINK JL AUDIO DID A GOOD JOB WIHT THOSE AMPS THE BAD THING IS THE PRICE ![]() |
Platinum Member Username: BestmankindSQ = SoundSplinter RL-s Post Number: 14236 Registered: Oct-05 | the slash series amps had a bit of an issue with heat. if you bump hard for a bit, the amps tend to get really hot. it won't shut down but they get really hot. it is my understanding that the v2 slash series fixed that. |
Silver Member Username: Mike11202Sewell, NJ US Post Number: 822 Registered: Nov-06 | JL AUDIO SLASH V2 FTMFW! Just bought a JL 300/2 V2 for $350 at a local dealer. I swapped it and this this is EXTREMELY Effecient, does not even touch my voltage level like my last amp did. It sounds 150% better. Definatley worth it IMO ![]() |
Platinum Member Username: BestmankindSQ = SoundSplinter RL-s Post Number: 14238 Registered: Oct-05 | awesome. congrats mike. |
Silver Member Username: Dakangofkrunk16Post Number: 772 Registered: May-07 | To what Chad said, yes they did improve that with Vertical, cast aluminum fins dissipate heat more effectively than typical amplifier designs, without resorting to noisy fan-cooling. JL Audio's exclusive Advanced Rollback circuit further protects against overheating without shutting your music down. |
