Wiring kits?
Username: Kicker101
Alberta
Post Number: 150
what to look for? I think i need 2 guage power wire but not sure check it out the BXI1606D specs....http://www.maxxsonics.com/hifonics/amps_brutus.html
Also if have a 1600 watt amp can i get bye with a 1500 watts amp kit? And could i use a 1/0 guage power wire?
Username: Splmonster
C-Town, OH USA
Post Number: 1355
knukonceptz.com <<< go there, they got the best prices
Username: Kicker101
Alberta
Post Number: 151
bump
Username: Mrskullz1
Brooklyn, New York
Post Number: 644
no need to bump lol
kingofcleveland gave u perfect response and 1/0 gauge wire would be fine
A pic is worth 1000 posts!!
Post Number: 8438
I've got many 2ga kits. Let me know if I have something you can use.
https://www.ecoustics.com/electronics/forum/for-sale/364653.html
Username: Kicker101
Alberta
Post Number: 153
k thats cool but i can use a 2000watt kit when i only have 1600 watts right?
Username: Gh0st_31
FL USA
Post Number: 568
yuh
Username: Warlok
Orlando, FL USA
Post Number: 343
I got 4 Ga kits if you just wanna skim by.
http://picasaweb.google.com/home
Username: Kicker101
Alberta
Post Number: 154
is it just me or do none of the wiring kits come with the actual sub wire (Sub to Amp wire)???
Username: Thumpinwith8s
2 RE8s, 300 watt Jense..., 133.3db@49hz!!
Post Number: 369
actually most of them come with RCA's, power wire, ground wire, and speaker/sub wires..
Post Number: 8449
The kits I have are amp kits. Power/ground wire. No speaker wire. Sorry.
Username: Kicker101
Alberta
Post Number: 155
oh that sucks cause i see on ebay most of the kits are just amp kits...
I have a hifonics Bxi1606d amp and (2) 12" kicker L7's (4 ohm)...so is a 250 Amp Fuse good?
also what should i go with Kicker..or ...Rockford kit?
Username: Kicker101
Alberta
Post Number: 156
bump
Username: Boomtank
Rochester, NY USA
Post Number: 325
if you would rather blow the inline fuse before fuses on the amp go with a fuse a little less then the total amp fuses. i.e. if the amp has 3 40amp fuses ( 120A total ) go with a 100 or 110A fuse. this one will blow before the amp fuses do.
else if you want the amp fuses to go first get a 130 or 140A fuse inline. and you will blow the amp fuses first.
Username: Boomtank
Rochester, NY USA
Post Number: 326
or get the same as the total. thats what i do.
Username: Kicker101
Alberta
Post Number: 158
k thanks man i think ill put a smaller inline fuse than the total amp fues together
