RD vs USAmp
Username: Skies
Courtenay, British Colu... Canada
Post Number: 781
Quality-wise which would you guys prefer?
USAmp DE500
or
RD Audio 1000.1?
Username: Mmaudioconcepts
Murray, KY
Post Number: 292
usamp
Username: Agatha
Yauco, Pr
Post Number: 40
nesesito los codigo de las caja las 00 & 01 me las pueden dar porfavor
Username: Imperial_designs
Lafayette, Louisiana
Post Number: 127
the RD amp is SOLID does over rated power and has a clean and efficient build/layout.. i wouldn't hesitate to get one...
Username: Its_bacon12
Hfl, Ny Usa
Post Number: 1238
both are great choices. i know little about RD audio but us amps are some of the best build quality around right now
Post Number: 133
not really.....
Username: Trey4sports
Post Number: 1472
zenon-built amps are hard to beat....especially now that USAMPS has hiked prices and began using a dealer-based network....RD > usamps
Hfl, Ny Usa
Post Number: 1243
ok how are they not joel?
you can find better bang for the buck but us amps makes some seriously quality amplifiers.
Post Number: 134
i stand by my RDs..... they are impressive amps to say the least... getting 2912(1456 per amp) @ 11.75 volts and 3.7ohm load(1.85 per amp) there strong... there rated for 1600 and they do it @ 12.5 volts and then some... there rated to do 800 @2ohm 12.5 volts and there doing almost DOUBLE that.. i tested one of them and it done right over 1800 @ 12.8
Username: Noob101
Taylorsville, Utah
Post Number: 28
Where can you find some RD Amps? Link?
Username: Snarl2004
Audioque 12 SD2.5s, Earthquake P...
Post Number: 1492
try emailing kevin from low-hz.com
kevin@low-hz.com
Post Number: 136
www.rdaudio.net..
Username: 04redmach1
Columbus, GA USA
Post Number: 1087
You can email me at:
lowhz01@yahoo.com
I don't use the other email. I will say the AX series US Amps are very nice, but that would be the only series I would get from them. Zenon is great :-)
Kevin
Username: Mixmastaspig
Canada, Canada Canada
Post Number: 960
Pm'd ya Kevin
