I need 4 Good(Great) 12" Subs
Username: Nissankicker
Grambling, LA USA
Post Number: 112
I need 4 good, preferrably GREAT, 12" subs for my car. They're goin' in a Sealed Box, stuffed w/ Polophyl, w/ about 1.3-1.5cuft. in each chamber. Soo, Please give me some suggestions.
PS - They need to be either Dual 2 or Single 4. ( I need a 1 ohm load ).
My currently considerations are:
Cerwin Vegas ( The chrome lookin' ones )
Treo TSXs
Kicker CVRs ( Kinda iffy on these )
JL Audio W3s
That's about it... So let me know!
Thanks!
DJ
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 12559
how much power
Username: Basssquared
Kansas
Post Number: 950
hopefully you have atleast 2000 watts for 4 12s and if you have 2000 watts then hopefully you got a HO alt and maybe a battery or two in two in the back and big 3
Username: Tremor1127
Team Fi Car Audio [:-]
Post Number: 1882
type Rz...
Username: Rovin
4 10 Pioneer...
Post Number: 11787
^^yep - type R really amazes in sealed boxes too.....
Username: 420alldaylong
Post Number: 2230
Try these out.
Memphiscaraudio.com
AudioQue.com
RDaudio.net
REaudio.com
Ficaraudio.com
DDaudio.com
SoundSplinter.com
Diamond Audio.com
Eclipse-web.com
Soundstream.com
Alpine-usa.com
JBL.com
Orioncaraudio.com
MTX.com
Phoenix Gold.com
ImageDynamicsusa.com
Polkaudio.com
Crossfirecaraudio.com
Grambling, LA USA
Post Number: 116
I have a Diesel Audio Titanium N2 3000.1 ( 1-ohm stable ). It's RMS is 2800-3000 @13.8. * Supposeably * I'm not denyin' it though... I have a Yellow Top in to back, and an upgrade Alternator ( 130 ) - '95 Honda Accord can only go up so much ( Original is 95, I believe ). Oh yeah, and a 3 Farad Cap. Hopefully that'll do it. It worked with 3 12"s, minus the battery on a Kicker KX1200.1.
I was told that Type Rs get hella loud sealed. Especially in quantities higher than 2. But I never tried a Type R.
What's the price range on them, as far as gettin' 4 of them?
Username: 04redmach1
Columbus, GA USA
Post Number: 1028
That Diesel Audio will probably give you a good 2000 rms at 14.4 volts. Are you wanting just pain loud or sound good too? Shoot me an email I will see what I can do for you.
Kevin
lowhz01@yahoo.com
Username: Denim
Www.TeamSSAudio.com, MD
Post Number: 345
SSA ICON
http://www.soundsolutionsaudio.com/products/icon/
Username: Insearchofbass
Post Number: 5572
"hopefully you have atleast 2000 watts for 4 12s and if you have 2000 watts then hopefully you got a HO alt and maybe a battery or two in two in the back and big 3"
you can get away with like 1000 rms and underpower them my buddy did that with his four 12's and then he installed a phoenix gold bass cube it boosts his spl 3 db when he uses it.....but if your maxing your subs power the bass cube doesnt seem to add anything...at least in out tests in my bros car
Grambling, LA USA
Post Number: 118
Kevin actally it's givin' me WAY more than 2000rms. I got my amp tested, Music Mart Inc. showed that it was more around 3100+ rms with my current setup.
But Kevin, i'll contact you... I only crank it up for LOUDNESS. ( Subs that is ) my highs and mids are SQ great.
Username: Tejcurrent
Post Number: 42
Why not some Fi SSDs? Everyone says they do great sealed and sound very good. They'd match your rms about as close as you're going to get too.
Grambling, LA USA
Post Number: 119
How much of Fi SSDs per sub?
Username: Th3pwn3r
Post Number:...
Post Number: 3588
"I got my amp tested, Music Mart Inc. showed that it was more around 3100+ rms with my current setup."
How was that test performed?What kind of power supply did they use?
Username: Theweasel
Steamboat springs, Colorado U.S. of A
Post Number: 870
194 shipped with copper coil option each. great choice though especially if you're going sealed.
Username: Southernrebel
Post Number: 5071
Hey DJ,
How did Music Mart test the amp?
Last time I was in there, they didnt even have a termlab.
Did they use a dummy load and a scope, or did they just come out to your car w/ a multimeter?
Just wondering.
Username: Jkidder
Spring hill, Florida Usa
Post Number: 1030
marshall, whats a good site to learn about how to benchtest amps?
Username: Jkidder
Post Number: 1033
bump
Grambling, LA USA
Post Number: 122
James and Pat came out there with a multimeter and played around w/ my system and went back into the store, did some crap over the computer.... And came up w/ the total.
Username: Oglejust
Post Number: 2277
^^^ prolly not accurate... ur suppose to use resistors for the load not the subs.
Grambling, LA USA
Post Number: 124
Hmmm... I know for a fact it's runnin' more than 1600 watts
Post Number: 52
Where can you get resistors that will handle 3100wrms? A multimeter alone will not tell you much, certainly not the rms. That won't tell you clipping either. How do you 'know for a fact'? I'd call them up and ask for rms ratings.
Grambling, LA USA
Post Number: 126
The amp wasn't/isn't clippin' because my gain is yet to be touched. I doubt an amp can clip on Bass Boost alone, with volume not exceeding 26, Bass on CD Play 0 and below... You won't find any, Dre, owner of SynQuest ( Another audio store where I stay ), knows to much *beep* for his own good... Explained to me that that amp is doin' 3000rms @ 1ohm.
But, ok... Everyone is entitled to his/her and their on opinion... That's why you post question on these forums. For everyone answers...
Don't knock anyone's stuff... Especially if you have heard it, have seen the setup or experimented w/ the EXACT product. Which no one in the forum, that's replied, has.
Username: Armstrong
Post Number: 53
wow that's weird. there's some kid that goes to my school named dj tucker.
Grambling, LA USA
Post Number: 129
What school...
Username: Armstrong
Post Number: 54
berea high school in ohio. i see you're not from ohio, so it's not the same person lol.
Grambling, LA USA
Post Number: 130
OHH! Hahahaha....
