Something for Subwoofer lovers
Username: Kanishka
Post Number: 31
checkout my new sub
Username: Bernymac
BME
Post Number: 3112
Very nice, looks clean.
Username: Kicker101
Alberta
Post Number: 137
ha we think alike
Username: Oneracistguy
TWO EGG, FL USA
Post Number: 767
hows it sound in the kicker prefab ive used a 12 l7 in a kicker prefab and it sounded pretty good
Username: Kanishka
Post Number: 32
tks
Username: Kanishka
Post Number: 33
JB I made this box, I got the specs from kicker and made it. I am using a DLS class D digital mono block to drive it. The sound, you can't ask for a better sub.
The punch is shaking all gates in the houses around and can be heard clearly even from the top of the road.
Username: Bernymac
BME
Post Number: 3116
If you truly made that box yourself, I am surprised. And good choice for an amplifier. I heard good things about DLS amps. Is that box ported or sealed?
Username: Basssquared
Kansas
Post Number: 970
dayum man your setup looks so sweet you should make me a box for my L7s
Username: Kanishka
Post Number: 34
the box is ported. the port is on the side. let me know if you need the specs i will get it for you. i got the kicker logo on the right hand side from ebay. you can find one there.
Make the box and get some professional to do the cushions.
Username: Rovin
4 10 Pioneer...
Post Number: 11796
looks very pretty but amp & cap attached to the box is NOT advisable ......
Username: Jkidder
Spring hill, Florida Usa
Post Number: 1036
"The sound, you can't ask for a better sub."
i certainly could.
but looks real nice. keep up the good work!
Username: Tejcurrent
Post Number: 56
Is that a slot port or aero/pvc?
Looks very nice, though I agree with above to remove the stuff from it.
Username: Kanishka
Post Number: 35
it is a slot port, i will post some pics from the side as well.
JK
what other subs are there i would like to try a different one for my new jeep.
Username: Denali_on_22s
Im just light up my......
Post Number: 2461
This is that dumbass that came on here and made a thread about what he should get and every recommendation we would give he would just bring up the L7 and disagree with us. Pr!ck.
Username: Vt_ahole
Post Number: 45
looks nice... where did you get the dls?
Username: Fearthisskyy
Dallas, Texas United states
Post Number: 266
listen to rovin & troy...
I love my dls a6 and I would NEVER put it on top of an enclosure, that's just asking for it to fall apart.
Did you build braces in the enclosure to make sure the amp is installed on something sturdy? You put it on the biggest side as well which means it will flex the most when you're bumpin'.
Other than that... it looks pretty clean, good job.
Username: Kanishka
Post Number: 36
i am planing to mount the amp to the car on top of the sub box. is this ok ?
Username: Adam_s
Post Number: 1652
No do not mount the amp on the sub box. The vibrations can cause damage to the amps internals.
Username: Kanishka
Post Number: 37
no i am not mounting it to the top of the box. i am going to mount it in the boot. or shall i put i under the back seat
Post Number: 269
you can put it under the backseat?
if it's under the backseat, it might not get as much circulation and can get very hot.
i would just put it on the back of the backseat...
