I'm freaking clueless
Username: Theweasel
2 12 FI SSD, Colorado U.S. of A
Post Number: 894
i'm hopelessly ignorant at tuning aero ports and calculating port displacement so can someone design me a box 23" wide, 18" deep, and however tall it has to be. needs to be 6 cu ft after displacement and tuned to 22 hz.
this is a home theatre box for a 15" Arsenal
Username: Rovin
4 10 Pioneer...
Post Number: 11808
http://www.carstereo.com/help/Articles.cfm?id=31
http://www.the12volt.com/caraudio/boxcalcs.asp
DIY ftw ......
Username: Insearchofbass
Post Number: 5679
basically the way I understand it it is area inside the port. So if its flared the increased width will raise the tune so youll need a longer length for the same tune
Username: Stnorris
RE SX 15, IA US
Post Number: 2189
if its 6 cuft net, and you want 22hz
it can have 2 4" ports .....21.4" long each
or 3 3"....18.5" long each
(flared ports)
your looking at some pretty long ports and not getting much port area....what size/kind ports do you plan on using??
Post Number: 5680
so a three inch port 3 x 3.25= 9.75 3.25 x 3.50=11.375 3.50 x 3.75=13.125=33.75 volume of port which would be equal to a 3 inch round by 11.25 inch long port
Username: Theweasel
Post Number: 895
the only ones i could find were the aero ports off of elemental designs website. i'm open to anything
Post Number: 5681
i did this wrong...so a three inch port 3 x 3.25= 9.75 3.25 x 3.50=11.375 3.50 x 3.75=13.125=33.75 its 34.25 but you get the drift
Post Number: 5683
we might be trying our hand at making aero ports soon (smiles)
Post Number: 5685
2.50 cubic feet net would need a 27.66 inch long port for a 35 hz tune but flared like I showed would need a 28.44 inch long port .78 inches longer for the same port tune
Post Number: 5686
im wrong again but im not gonna correct it bottom line its simple math once you understand what your changing and the port will always be longer using a flared port
