New member Username: Noob101Taylorsville, Utah Post Number: 5 Registered: Jul-07 | Kinda new to all this so i don't exactly what to look for but i was looking at some Sony XS-L154P5B and was wondering if their any good or is their something i should know about these subs or Sony as a brand all together? |
Gold Member Username: CtmikeCt. Post Number: 4793 Registered: Feb-06 | sony car audio sucks. |
Gold Member Username: HdubbFarmington, Nm Usa Post Number: 2236 Registered: Nov-04 | yeah the subs amps speakers are horrible some of their decks use to be ok. how much you lookin to spend? whats it goin in? what type of music do you listen to? sq? or spl? |
New member Username: Noob101Taylorsville, Utah Post Number: 6 Registered: Jul-07 | Thanks well I'm looking to spend around $200 and it's goin in a 2003 ford mustang listen to mostly rap and reggae |
Silver Member Username: FearthisskyyDallas, Texas United states Post Number: 259 Registered: Apr-07 | $200 on subs alone? then get one 12" Fi SSD @ www.ficaraudio.com in a Mustang that should be plenty loud |
Gold Member Username: HdubbFarmington, Nm Usa Post Number: 2238 Registered: Nov-04 | hmmm that doesnt ive you a lot of options. there is a sub called a maw12 its like 70 bucks there was a review on it and it did real well. then you might be able to find a 300 watt amp for 130 to 150. wooferetc.com may have an ampp for you. but then youll need an enclosure and wiring. those sony subs are over rated. thy would be ok if you just want a lil bump in the trunk...or even junk in tha trunk lol. but there is better for the money |
Gold Member Username: HdubbFarmington, Nm Usa Post Number: 2239 Registered: Nov-04 | and always go by rms power and need to figure out what the amps load is stable at. ike 1ohm or 2ohms. say if your runnin one sub and one amp. if the amp is two ohm stable then youll either need a svc 2ohm sub or a dual 4 ohm voice coil sub or a dual 1 sub. |
New member Username: Noob101Taylorsville, Utah Post Number: 7 Registered: Jul-07 | i could get a lil more cash maybe something near 300 and this is just on the Sub not the Amp but I'd like to hear some good recommendations on amp to go with the sub |
New member Username: Noob101Taylorsville, Utah Post Number: 8 Registered: Jul-07 | bump |
Bronze Member Username: Lil_jCantonUS Post Number: 40 Registered: Feb-07 | love my MAW-12 it's now my HT sub and I have a MJ-18 for the car live it to |
Gold Member Username: HdubbFarmington, Nm Usa Post Number: 2247 Registered: Nov-04 | where is taylorsville utah? near the four corners maybe???! |
New member Username: Noob101Taylorsville, Utah Post Number: 9 Registered: Jul-07 | Warren - it's near the capital Salt Lake City why? |
New member Username: Noob101Taylorsville, Utah Post Number: 10 Registered: Jul-07 | Warren - it's near the capital Salt Lake City why? Jeremiah - If you would recommend either of thoose can i get a link on where to find them? |
Bronze Member Username: TejcurrentPost Number: 49 Registered: Apr-07 | For 300 get a Fi BL in the largest size you can. How much room do you have to work with? A hifonics 2006d is a decent amp for the money, or a Sundown 1500 would be a great match for that sub. |
Bronze Member Username: Noob101Taylorsville, Utah Post Number: 11 Registered: Jul-07 | thanks Troy do you have a link on where to find those? Not sure how to say this but i got 15" Vertical 37" Horizontal and 31" from the back of the trunk to the front if that makes sense... |
Bronze Member Username: TejcurrentPost Number: 54 Registered: Apr-07 | Ficaraudio.com then go to speakers. Maybe squeeze a 15 in there? |
Silver Member Username: TheweaselSteamboat springs, Colorado U.S. of A Post Number: 877 Registered: Mar-06 | 15" BL for the woofer Amps: kicker zx1500.1 hifonics 2006d soundstream pca1500d all 400 or under here's your box:http://www.subwoofertools.com/forum/ported-box.asp?Ew=37&Eh=15&Dia=9&Xmax=21&Vd= .18&NumW=1&Vb=4&Fb=33&Qts=&Vas=&Fs=&CE=0 |
Bronze Member Username: Noob101Taylorsville, Utah Post Number: 12 Registered: Jul-07 | Thank you i think I'm going to pick up one of those but would you mind explaining what these are? P Chamfer,Flatwind:,Extreme Lead,Universal?? those are the option's on it and don't know what those 4 mean... |
Silver Member Username: TheweaselSteamboat springs, Colorado U.S. of A Post Number: 878 Registered: Mar-06 | basically they all have something to do with handling more power. if someone more knowledgable wants to specify feel free |
Gold Member Username: Tremor1127Team Fi Car Audio [:-] Post Number: 1893 Registered: Aug-06 | http://www.soundsolutionsaudio.com/forum/index.php?showtopic=7154 that will tell almost everything you need to know about the BLs including the options... y |
Gold Member Username: Tremor1127Team Fi Car Audio [:-] Post Number: 1894 Registered: Aug-06 | i didnt mean to say "y" at the end. i was going to say "you dont need spl leads" but erased it assuming you would figure out you DONT need spl leads... and the BLs are bad, you will likey... |
Gold Member Username: BernymacBME Post Number: 3109 Registered: Sep-04 | Options explained as well as recommended enclosure. http://www.soundsolutionsaudio.com/forum/index.php?showtopic=7154 |
Bronze Member Username: Noob101Taylorsville, Utah Post Number: 13 Registered: Jul-07 | thanks alot guys. |
