Spivey17323
Username: Koz1031
Monticello, IN United states
Post Number: 488
You sent me a private message asking about the MA Audio 898.
No it will not do 600 x 2 at 2 ohms
You need the MA Audio HK 1998 It will do 600 X 2 at 2ohms.
I tried to get back to but couldn't. Also sorry about taking so long, but somehow that message got put in my trash bin,(probably the wife). Hope this one makes it.
Username: Koz1031
Post Number: 491
I messed up, the 1998 is a mono amp it does * Amplifier Class N/A
* Number of Channels 1 - Mono
* RMS Power (4 ohms) 600 watts x 1 channel
* RMS Power (2 ohms) 1200 watts x 1 channel
* RMS Power (1 ohm) Not Stable
* Bridged RMS Power Not Bridgeable
* Peak Power Output 2400 watts approx.
* Minimum Impedance Unbridged 2 ohms
* Minimum Impedance Bridged Not Bridgeable ohms
* THD at Rated RMS Power 0.05%
* Speaker Level Inputs No
* Amp Preamp Outputs Yes - 1 pair
* Built-in Crossover Yes - HP / LP
* High-Pass Crossover Frequency 40 - 250 Hz
* Low-Pass Crossover Frequency 40 - 250 Hz
* Subsonic Filter N/A
* Signal-to-Noise Ratio 90 dB
* Channel Separation N/A
* Bass Boost 0 - 18 dB
* Bass/Gain Remote N/A
* Fan Cooled Yes
* Fuse Rating N/A
* Warranty 2-year Manufacturer's
the 898 does # 2x 300W RMS @ 4 Ohms Stereo
# 2x 500W RMS @ 2 Ohms Stereo
# 1x 1200W RMS @ 4 Ohms Mono
I believe it also does 1200 X 1 at 2 ohms. at least according to the local installer. But I haven't verified that.
Either amp should work for your app.
