Hey everyone
Username: Big_edge_head
Milwaukee, Wisconsin USA
Post Number: 269
quick question
would i have to reset the gain on my amps if i hooked up this eq since its got a 7vrms out put.
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=16889
Username: The_image_dynamic
San Diego
Post Number: 2214
No because the same voltage from your HU is coming out of it. It has the POTENTIAL of 7 volts, it doesn't boost what you already have.
Post Number: 273
but then how do i set the sub level and the volume on the EQ?
