Amp question
Username: Schrado
Post Number: 16
what does buyin 2 amps do ..does it increase the amps to the subs?
Username: Thumpinwith8s
2 RE8s, 300 watt Jense..., 133.3db@49hz!!
Post Number: 295
2 amps will give you more wattage to the subs. in other words, if you had one amp putting out 500 watts to 2 subs, each sub would get 250 watts, but if you added another 500 watt amp, then you could run one amp to each sub giving each sub 500 watts.
