Charging system
Username: Theweasel
Steamboat springs, Colorado U.S. of A
Post Number: 801
do i need to upgrade my charging system if i get a hifonics bxi 2006D with a 105 amp stock alternator? i have a audiobahn a8000t and have no voltage drop from 14.4v. i won't be playing at more than 2/3 volume for more than 20 minutes at a time
Username: Big_edge_head
Milwaukee, Wisconsin USA
Post Number: 232
u should be fine. do the big 3 too
Username: Adam_s
Post Number: 1496
Yes you do need to upgrade your charging system. That amp will put out about 1800-2000 watts RMS and you will see voltage drop if you only have that stock alt.
Username: Theweasel
Post Number: 802
how much voltage drop?
Username: Theweasel
Post Number: 803
bump
Username: Theweasel
Post Number: 804
why no bump
Username: Theweasel
Post Number: 813
all i have heard is that capacitors don't do anything but i found this on rockford's website. it says for musical applications a capacitor is the easiest most reliable upgrade.
Username: Adam_s
Post Number: 1505
^^Thats because they are just trying to sell more stuff. It doesnt help unless you have the electrical to back it up and then the help it does do is not very much. It is not possible to know how much voltage drop there will be, but I can guarantee that you will not see full potential out of that amp without an upgrade. Also you risk the chance of running a clipped signal to your subs. MMMM do I smell burnt coils.
Username: Mygame5982
I Got More Watts Then ..., TEXAS US
Post Number: 1980
man forget that..
you dont need a alternator : )))
i have 2500watts..no alternator! ahha
and no clipped subs over here!!
Username: Theweasel
Post Number: 817
2500 watts! jesus
Username: Theweasel
Post Number: 818
bump
Username: Nd4spd18
Southeast PA
Post Number: 3035
Yes you need an HO alternator to run 2kw power.
James caroll apparently flunked elementary school and can't do the simple math necessary to know that its physically impossible to get 2500 watts from a stock alt
Username: Theweasel
Post Number: 820
so what's the biggest amp i could put on my electrical system
