Fi Q12 Setup
Username: Singhsane
Scarborough, Toronto Canada
Post Number: 70
Im in the process of putting together a system for my '02 Trailblazer...i've decided on a single Q12...just wondering whether i should go with the Dual 1 or Dual 2? what the difference between the two are and whether i should get the "BP Power" option? Im also looking for an amp for the sub...any suggestions?
Username: Fearthisskyy
Dallas, Texas United states
Post Number: 208
dual 2, so you can find an amp that puts out more power at 1 ohm
Username: Nd4spd18
Southeast PA
Post Number: 3009
^^^^ you match the sub to the amplifier when you can, not the other way around.
Choose an amp, if its 2 ohm stable you want the dual 1 sub, if its 1 ohm stable you want the dual 2 sub.
Username: Singhsane
Post Number: 71
alrite...any suggestions on amps? something thats gonnna gimme good clean power...and any ideas on the BP Power option?
thanks for the help BTW
Username: Ctmike
Ct.
Post Number: 4753
power option increases the rms by several hundred i believe. check their forum for all the info you'll need.
www.soundsolutionsaudio.com
and what's your budget for an amp?
Username: Singhsane
Post Number: 73
hmmm...I picked the Q12 cuz i didnt want to upgrade my alternator...if i were to go with the power option would i need to think about upgrading?...and budget on an amp...im willing to spend about 400 - 500...
Username: 04redmach1
Columbus, GA USA
Post Number: 968
If you want a nice strong amp in that price range, the RD1000.1 would be nice and will be fine on stock charging. If my Focus can handle it, anything can hehe.
Kevin
Username: 420alldaylong
Post Number: 2152
Sundown SAE1000D make sure the sub is dual 2ohm
Kicker ZX1000.1 make sure the sub is dual 1ohm
Username: Basssquared
Kansas
Post Number: 816
S.Singh got PWNED
Username: Singhsane
Post Number: 76
i'll take a look at those amps...any suggestiosn on the BP Power option?
Username: Ctmike
Ct.
Post Number: 4758
get the bp power option if planning on running more than 1200wrms to it daily, imo.
Username: Singhsane
Post Number: 77
wat exactly is/does the bp power option do?
Username: Mygame5982
I Got More Watts Then ..., TEXAS US
Post Number: 2001
get a orion 1200d
Username: Singhsane
Post Number: 78
i was actually looking at the orion 1200d right now...ive decided its gonna be one of the following...
1. Sundown SAE1000D
2. Sundown SAZ-1500D
3. Orion 1200D
Out of those 3 which should i go with or can anyone gimme reasons why NOT to go with one of those?...still tryna figure out what the whole BP Power option is?...
Username: Ctmike
Ct.
Post Number: 4759
did you even bother clicking the link i gave you, the one to the fi forum? last time, try reading. if this doesn't help, search their forum some more.
http://www.soundsolutionsaudio.com/forum/index.php?showtopic=8161
Username: Ctmike
Ct.
Post Number: 4760
bump for the o.p. to see this.
Username: Singhsane
Post Number: 79
ahhhh...ctmike thank you so much for that...i tried searching the link you gave me before but didnt have much luck...thanks a lot, that really explained it...now to finalize on an amp...any suggestions from these 3?
1. Sundown SAE1000D
3. Orion 1200D
Username: The_image_dynamic
San Diego
Post Number: 2128
Like others above have been trying to tell you... get the SAE1000D. Not only does a Q12 not need any more power than that, Orion doesn't make the 1200D anymore and if you are talking about the D1200, that amp only puts out 600RMS @ 1ohm and the Sundown SAZ1500 would be too much for your stock alt. Get the dual-2 Q12 and the 1000D and you're good to go.
Username: Singhsane
Post Number: 80
thank you for finalizing that for me...done and done...Q12 Dual 2 with a SAE1000D...the Q12 has been ordered...just looking for places where i can pickup the amp now..thank you VERY much for all your help...much appreciated!
San Diego
Post Number: 2141
Contact Ben or Kevin here, they will hook you up on that SAE-1000D:
http://www.low-hz.com/
