DVC wiring question
Username: Doconpoint1
Park Forest, IL
Hey, i'm kind of new to car audio guys and new to the site. So here's my question.
On the 12volt site it says that you can wire 2 subs with 4ohm DVCs so that a amp can read a 4ohm load. Now i was wondering if instead of a mono amp, you had a 2 channel, could you have each sub wired to read 4ohm total a piece so that you can have 1 sub hooked to 1 channel at 4ohm and the same for the other sub. And if not would it just be better to get a mono like i've been thinking about mainly. Thank you..
Park Forest, IL
sorry. i meant 2 subs with 4ohm DVCs so that a 2 channel amp could have each channel read a sub as having 2 ohms.
Username: Imalik
SD2.5......ED9.1=Boom, New Jersey Audioque...N...
Post Number: 409
Here you go
Park Forest, IL
Thanks. Is that diagram for a mono sub.
Park Forest, IL
oh, that was meant for your other diagram. But with the 2 ohm diagram, can u do that for each woofer with a 2 channel so each channel sees a 2 channel load.
Username: Imalik
Post Number: 410
Its going to be a 2 ohm load no matter what kind of amp
Park Forest, IL
i know that it's going to be the load no matter what amp, i don't think u understand what i was trying to say. But thanks, i think i got what i was trying to say.
Username: Imalik
Post Number: 411
Lets see if I can give you a better answer..If you have 2 4ohm subs you can wire them at 1 ohm or 4 ohm...If you have 1, 4ohm sub you can wire it to 2 or 8 ohm...A mono amp will be better choice.
Park Forest, IL
Post Number: 7
I understand the options for ohm loads. U already answered my question though actually. But thanks for being so helpful anyways. I was just wondering about options for a 2 channel just in case. But i've been pretty set on a mono. Just making sure i understood my avenues.
