Silver Member Username: Skibum12189Cleveland Post Number: 810 Registered: Mar-06 | Is the Kicker SX Remote Control just a over priced remote bass controller or does it legitimately do anything? |
Silver Member Username: Skibum12189Cleveland Post Number: 815 Registered: Mar-06 | bump? |
Gold Member Username: Freezeman_7C.FREE Post Number: 1479 Registered: May-06 | cal i honestly dont know man.. no idea, sorry |
Gold Member Username: The_image_dynamicSan Diego Post Number: 2065 Registered: Dec-06 | http://www.cardomain.com/item/KIC04SXRC |
Silver Member Username: Skibum12189Cleveland Post Number: 817 Registered: Mar-06 | thanks brad and damn that thing is sweet, makes me want sx amps....you can look at each amps voltage and even temperature, not to mention adjust anything from where ya mount it... |
Gold Member Username: LoudonPost Number: 1272 Registered: Jun-04 | its defintely worth it man .. just takes a long time to get used to ... ive used them on many sx amps ... multiple amps can be intertwined together ... so you can tune your amps from the front of ur car ... its more of an ease of use kind of thing the best part about is the fact that u can control more then one amp with it ... hope it helps ... ne more questions bout hit me up |
