Anyone use gas treatment for your car?
SQ IS THE ONLY WAY
Post Number: 13710
yesterday before i filled up my gas tank, i bought a bottle of chevron gas treatment. i put that in and it feels like my car is alot smoother and the response is better. my car feels like its faster.
you think that is all in my head?
Username: Boomtank
Rochester, NY USA
Post Number: 280
no, gas treatment ups the grade of the gas you use 1-2 grades. so if u use 87 or 89 you'll have 89 or 91 which is like using premium gas. it will run smoother and could posible add a few horse. but nothing too drastic. some brands are a waste of money, make sure the treatment says Made with Jet Fuel.
SQ IS THE ONLY WAY
Post Number: 13711
well the one i bought also says it cleans the fuel system.
Username: Boomtank
Rochester, NY USA
Post Number: 282
yeah if your injectors are dirty and you run cleaner you car will run alot smother also.
Username: Extrmndor3
IF U HEAR ME... crazydbs.com
Post Number: 5613
use the seafoam treatment is the expensive one but is worth it :-)
A pic is worth 1000 posts!!
Post Number: 7609
On a fill up using the treatment is probably cheaper than buying the higher octane fuel at the pump. Think about it, the difference between regular and high test is what, $.20-$.30? On a 20 gallon fill that's $6. How much is the treatment? See my point?
