Do systems with one 12" get loud?
Username: Fearthisskyy
Carrollton, Texas United states
Post Number: 137
I actually am now considering getting the IDmax 12" v3 d4 because I want a SQSQSQ system since I listen to a lot of underground hiphop and want all the kicks to hit well.
Will this be loud still? Incase I do want to listen to some rap and bump around town...
Username: Extrmndor3
IF U HEAR ME... crazydbs.com
Post Number: 5583
ill get you a avalanche a true sq woofer and louder and better than the id max for 250
A pic is worth 1000 posts!!
Post Number: 7458
Rob, where do you have access to an Ava? Any size.
If you do, where were you 6 months ago?
Username: Cenus
Hicksville, Ohio
Post Number: 3275
the max will blow you away sq wise, spl its decent, one 12 in a good ported box with 800wrms i could see doing low 140 playing test tones, so a high 130 bassrace, which is average, overall though i'd get the ava its a low end monster great for rap and will get pretty loud, you might wanna check ebay, i think theres a 12 on there.
Post Number: 5584
no there are no 12 inch on ebay not even a 15 :-)
also the id max cant keep up with the sq of the avalanche.
and paul i only have a 12 inch thats it
Post Number: 139
I don't listen to RAP, it's basically hiphop. mostly kickdrums and musical instruments (i.e. piano, jazz, drums). I want something quick and tight that can keep up with the bassdrum.
Username: 04redmach1
Columbus, GA USA
Post Number: 921
You can get pretty loud with 1 12. As long as you do it right :-)
Kevin
Username: Theweasel
Steamboat springs, Colorado U.S. of A
Post Number: 764
80% enclosure
20% equipment
Username: 420alldaylong
Post Number: 2013
33% Equipment
33% Enclosure
33% Install
1% Luck
Username: Johnfiac
A-ToWn, Kingkong ain... I got Chuck ...
Post Number: 3146
You going sealed or ported? Ported will give you the SPL advantage but sealed will give you the SQ advantage (depends on sub also) are you looking for SQL or just SQ?
Post Number: 140
i want to go sealed to get the most SQ out of whatever i buy, but if it doesn't satisfy my loudness, i'll probably try both
Username: Likeapuma
Washington/Utah
Post Number: 96
Get the IDMax.
-C
Post Number: 141
is the AA avalanche really better than the IDmax SQ wise? if it is... then I'll probably be interested plus you say it gets louder as well which wouldn't be bad on top of the SQ
Post Number: 5589
the avalanches are one of the best sql subs out ever made.... really great subs one of hte bests and were one of the few subs that really used the xbl"2 technology witout any problems like most other woofers.
Post Number: 142
yeah I'm actually reading up on it right now, and I've only seen good things about it. They are comparing it w/ IDmax and SS Rl-p constantly... which is what I basically am wondering as well.
Post Number: 5591
you were the guy that send me an email??? if you didi respoded you back.
the ascendant audio is better than the idmax and alot better than the rl-p like i said you have tog et your hands on both and see foryourself wat i mean :-)
Post Number: 143
i don't think it was an e-mail...
i sent a PM
Post Number: 145
what are the specs for the AA avalanche? i wish there was info on the AA website...
and how long will you be able to get the Ava for?
I was planning on buying my HU and frontstage this weekend and waiting for my substage, but i might buy the sub this weekend instead of the frontstage if it'll be gone after this weekend.
Post Number: 5595
the avalanche is ready to go like i said you got messenger aim???
zpeedyrosales =aim
Avalanche 12"
Fs 23 Hz
Vas 80 Liters
Qms 4.36
Qes .39
Qts .358
Znom 4 ohms
Re 2.8 ohms
Mms 197 g
Sd 480 cm^2 - (74.4 sq.in)
Pnom 800 watts
^^^^^a true sq woofer :-)
Post Number: 147
i'm at work so i can't get online... i've been reading this forum everyday at work along with caraudio.com
i'm basically getting paid to research car audio
but i'll hit you up on AIM later once i get off at 6pm
and is this sub BNIB or used? i don't think you replied my PM
Username: Longbluesquid
Post Number: 156
1 12 will sound good in a system all you need to do is get really good components speakers and ofcourse amplify them then you let the sub blend into the music and ofcourse you have to have a good enclosure because if you build too big or too small then your sub wont perform well....
Post Number: 5600
dude i did send you or repospoded back to your email man
Username: Denim
Www.TeamSSAudio.com, MD
Post Number: 313
Did a 144.3 on a single 12 with a dead battery and a low volt deck.
Post Number: 148
i don't know how to check it then... I clicked Check New Messages and it said search found 0 items or something...
i just want to know if it will be brand new or used...
Post Number: 5602
i did not replyed to your pm i replyed to your email is used but like new.
check yoru email
Username: Jesse59672
OKLAHOMA
Post Number: 450
im doing 143 with one 12 on 650 rms
Post Number: 5603
stop posting number you might make me change my mind and keep it :0 but you know the baby needs some stuff
SQ IS THE ONLY WAY
Post Number: 13675
metered my pioneer sub the other day. i was doing 144.2 with little over 300wrms.
Post Number: 149
okay, i have no idea what 140 190 120db is sorry.
i think it'll be loud enough sorry for this horrible thread title.
ps. i never e-mailed you though KingRob! i just PMed you... lol
Post Number: 5604
hey chad when your gonna get your rl-s??
Post Number: 150
pss. get online i'm on aim express haha
SQ IS THE ONLY WAY
Post Number: 13676
rl-s is shipping today so i'll get it tomorow.
Post Number: 5605
a fu ck i though yours were gonna get shipped on monday and maybe youll get it today.
but hey tomorrow cool get the camera charger makes some wings cuz ull smeel what the rocki s coocking..
Username: Johnfiac
Post Number: 3153
the rock dont know how to cook
Post Number: 5606
i teach him how to coock and rock like a rock/
Username: Hdubb
Farmington, Nm Usa
Post Number: 2104
which avalanche? the xbl^2 version or the newer one? the idmax is a very good woofer. and so is the avalanche. do they even make he avalanhe anymore. i thkn either one will make you happy. i would put it in a low tuned vented box. it will give you a good amount more of spl but also maintain good sq all the way down to lower tones. i have my 15 xxx in a 6ft box tuned to 27 hertz. with 800 watts it can playa 33 test tone at 141. not super loud but it is a little underpowered but that is pretty damn loud for 33hrtz. imo. its such a different sound though. i love it.
Username: Shortysetnies
Rock Vegas, NC US
Post Number: 1386
does anyone have the link to the site where they threw a sh!t ton of wattage on a sony xplode and got pretty good numbers? I can't find it and this thread reminded me of it
Username: Rovin
4 10 Pioneer...
Post Number: 11678
to answer ur thread title - YES ! 1 12 done right can sound as if its 2 12s which is what ppl thought it was when i had my measely 500wrms model 1 12 atomic ......
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 12431
F.U.C.K Tha Sh!t.. IDMAX>AVA...
Post Number: 152
have you heard both?
would you think two 12" RD Classics would be great for hitting kickdrums quick. tight, and accurate? will it be a louder set up than the 12" ID max giving more cone area w/ about the same amount of power going to them?
