Baseless again.
Username: Thumpinwith8s
Formerly known as Wolf...
Post Number: 126
well, not completely. I was messing with the amp today and noticed that one of the subs sounded different from the other. I then noticed that same one felt like air was comig out of it. Well, I turned everything off and sure enough...the part where the cone connects to the rubber of the sub (not the foam surround, but the part of the sub between the surround and the cone) has about a 3 inch section that has come loose from the cone. SO>How do I fix this guys, will superglue work?
Username: Dakangofkrunk16
Post Number: 566
Can you take a pic... I'm not quit folowin you
A pic is worth 1000 posts!!
Post Number: 7497
Ok, so what you're saying is.......what are you saying?
Post Number: 127
Username: Jblanford
Post Number: 1474
are you talking about where the voice coil/former attaches to the cone ?
Post Number: 7498
Do you mean there's a seperation between the surround and cone about 3" long? Between the cone and dust cap?
Already broke and she still doesn't know yet, does she?
Post Number: 7499
Ahhh, the dust cap.
Post Number: 7500
I would staple it.
Roofing staples. Galvanized.
Post Number: 128
paul, yes...seperation between surround and dustcap, will superglue fix it? or am I fucked?
Post Number: 131
woops, mean cone and dustcap
Username: Southernrebel
Post Number: 5007
I have some black CA glue here are the shop...ease by some day, i'll fix you up.
Post Number: 7502
Rubber cement and you're good. You don't want anything getting into the coil, then you're fucked.
Post Number: 132
sh!t, I'll take a pic and put it up later
Post Number: 133
CANAAN!!MY SAVIOUR. I'll drop by on Monday....but I'm still gonna take a pic and show ya'll later.
Post Number: 134
ok, I remembered wrong about where it was seperated....anyway here's a pic
Username: Snarl2004
Audioque 12 SD2.5s, Earthquake P...
Post Number: 1362
damn. ide say rubber cement
Username: Snarl2004
Post Number: 1364
or just go mooch off of canaan
Post Number: 7505
Damn they're cute.
Like subs for chipmunks.
Post Number: 136
probably gonna go see Canaan, he knows more than I do.....and F@CK YOU PAUL, they sound real good for what they are...a lot better than Sony's....lol
Post Number: 7508
Post Number: 5010
How the hell did you manage that???
Dont play them like that...unhook them.
Post Number: 137
dont know how that happened, if I let go of it, it falls back into place. and OF COURSE I have the amp turned off and the RCA's are unhooked....it is fixable isn't it?
Username: •cam•
Post Number: 563
well they were glued together in the beginning, right?
Post Number: 7511
Is it just me or do I see a small tear on the surround just to the right of your finger?
Post Number: 139
nope....must be a shadow, or trick of the light...and cam...uh yeah, they were glued together, of course
Post Number: 140
bump
Username: •cam•
Post Number: 565
lol, I was answering your question.
"it is fixable isn't it?"
