Box question??
Username: Texas_bass
Houston, TX
Post Number: 448
Would it be better to build a box with 2 subs and one vent of a box that has 2 vents with a devider between the 2 subs
Username: Slimdog53185
Bowling Green, Kentucky U.S.
Post Number: 54
I've done both. If you want spl you should leave out the divieder. As for the port I like to have two ports on opposite sides of the box. Thats just me though.
Houston, TX
Post Number: 449
i was thinking more incase one goes out so i could still run one if needed
Post Number: 55
I have the same opinion. Thats why most of my boxes have a divider. The box I have now is a lot louder since it doesn't have the divider. Its really just your preference. If one sub fails you should have enough time to turn it down before damaging the other one.
