Another 2nd batt thread lol
Username: Splmonster
C-Town, OH USA
Post Number: 1241
i know charlie has one down there, but i have a question of my own. i have 4 ga wire ran right now, and the stock batt up front. wats the cheapest way to make this work?
Username: Carguy
Post Number: 6311
What are you saying? You trying to add 2nd battery as well? Look at Charlie's thread cause your question is very similar.
If you like taking chances, you can just wire the 2 batteries in parallel and cross your fingers. I'd personally install an isolator/relay so that the starter battery doesn't get drained.
C-Town, OH USA
Post Number: 1244
well my main question was about the wire gauge, i thought id have to throw an isolator in there some where but i juss wondered cuz i have only 4 ga wire and a kinetik hc2000
Username: Oglejust
Post Number: 1997
u can do it... i use 2 ga
C-Town, OH USA
Post Number: 1246
bump
Username: Carguy
Post Number: 6316
Look at Charlie's thread. He posted a picture of adding 2nd battery. 4ga you already have is good enough.
Username: Trey4sports
Post Number: 1302
well i have a two batt setup. one is sealed in the back by my amp and a lead acid batt up front in the batt compartment. i drove it everyday for 2 weeks no porb. i jsut recently went about 5 ays w/o driving it and the batt was drained.
Username: Hdubb
Farmington, Nm Usa
Post Number: 2094
you can use 4 ga. from your bat under the hood to the battery in the back, because it is now just a charge line. it is more important to run your bigger line brom bat to bat or bat to amp. and isaac said the isolator is a good investment.
C-Town, OH USA
Post Number: 1260
wat exactly does a batt isolator do and can i get a link?
Username: Cried
Erie, PA US
Post Number: 355
bcae1 i dont have an exact link it is on the left hand side of the screen towards the bottom the long scroll list about an isolator.
