Look at this please
Username: Jester_king
Post Number: 236
ok sorry for the title, but I couldnt think of one, but yeah the question, I am planning on getting my first system soon, and I was wondering if you think 1000rms is to much, I either want 2 10" diamond D6's with 500rms each or a single 15" D6 on 600 rms, and what I am wondering is will the 400wt difference be big or should I just go for the 1000rms system???
Username: Thumpinwith8s
Formerly known as Wolf...
Post Number: 112
with almost double the power there will definately be a difference ....also 2 10's have more surface area than one 15. I'm going to bed now, maybe someone will give you more of an answer
Username: Koz1031
Monticello, IN United states
Post Number: 440
What amp r u planning on using Ryan???
The 10's are dvc 2 0r 4 ohm, and so is the 15.
You'll need either a 2 ohm stable or a 1 ohm stable depending on how you wire them up.
Specs on the 10's are
D6 10" Subwoofer
Hard Annodized Alloy Cone and Dust Cap
EPDM "Omega" Surrounds
Cast Alloy Aluminum Basket
Dual Mirror Image Flat Spiders
Isolated Heavy Duty Lead Wired
Intercooled Motor Design with Vented Pole Piece
Ferrite Magnet
Available with Dual 2 ohm or Dual 4 ohm 3" Extended Voice Coils
Power Handling NOM/MAX: 500/1000 Watts
Sensitivity (2.83V/1m):
84 dB SPL
Freq. Response: 23-250 Hz
Mounting Depth:
6.2 in.
Diameter:
9.2 in.
Specs on the 15 are
Ferrite Magnet
Power Handling NOM/MAX: 750/1500 Watts
87 dB SPL
Freq. Response: 20-250 Hz
Mounting Depth:
7.4 in.
Diameter:
13.9 in.
so unless diamond audio's quality has dropped in the last couple of years, you would be seriously underpowering the 15.
And depending on which amp u r using, u could be underpowering the 10's.
Username: Skibum12189
Cleveland
Post Number: 730
definitely get the 2 10's, the d6's will you give you really clean tight bass and with 1000 rms and 2 10s thats gonna get loud too
Username: Johnfiac
A-ToWn, Kingkong ain... I got Chuck ...
Post Number: 3116
I would do 2 10's unless your trying to get it louder at lower notes, but i dont think the 1 15 will beat the 2 10's either way.. 2 15's FTMFW!@!
Username: Boomtank
Rochester, NY USA
Post Number: 276
10 tens dont have more cone area than a 15.
(pie) * r ^ 2 = area of a circle
3.14 * 10 ^ 2 = 314sq^in * 2(subs) = 628sq^in
3.14 * 15 ^ 2 = 706.5sq^in
Username: Phil_salisbury
Post Number: 257
Eddy, I see that you failed math class in school.
The radius of a 10" subwoofer isn't 10", IT'S 5".
Username: Mike11202
DE US
Post Number: 720
Username: Boomtank
Rochester, NY USA
Post Number: 277
sorry im at work and did the math real fast. but its still not more area for 2 10" subs
157sq^in for 2 10's
176sq^in for 1 15
Post Number: 238
I plan on using a sae1000D to power either, I'll either wire the 10"s(dual 4) in parallel to get 1 ohm or with the 15" wire it to 2 ohms and get 600rms, and killa that was my exact thoughs last night lol, I would but then i would need to get a saz1500D and thats a bit more then the other, but if I could get the 1500 for around the same price I'd do it
