Finally got my HD3 installed
Username: Joebruce
15 Inch Wang...
Post Number: 931
Sorry no pics yet. Well i got my box from Logan on Friday and installed everything. First off my box is fallin apart just about every screw is stripped and there are a ton of leaks in it and one of the boards are split at the top. I had to replace a few screws as soon as i hooked it up b/c they rattled out and the box was makin loud noises from the wood hittin together. That kinda helped but its still very leaky. Im going to have to replace just about every screw and caulk the sh*t out of it and see if that helps. But as soon as i get another 200 bucks im gettin Fisher Customs to build me a good box. So overall im dissappointed in my HD3 it sounds OK on some songs at low volume but sounds like crap on the lows and anything at higher volumes cuz the box is about to fall apart. I need a new box and about 2000watts and then itll problly sound good.
Username: Logan__tille
Team RevolutionImortal Box ...
Post Number: 7631
WHat?????? Are you fu*king serious? Take pics of it..
It sounded great with my Alpha in it. Was it damaged from shipping?
Username: Volfenhagking1600
SSD Wangin, Shawano, Wis... USA
Post Number: 782
I dont know if its from shipping or what but where the arrow is pointing...that peice wiggles back n forth a little bit it might just be a stripped screw but thats easily fixable but if TWiZTiD is serious...Damn!
Post Number: 7634
Goddamn I suck.lol
Does it affect the sound Jamie? Is it flexing or moving the whole board?
Post Number: 783
no it doesnt affect the sound... its fine
Username: Jblanford
Post Number: 1176
imortal box building FTL
Post Number: 7638
OH Thank God:-)
Post Number: 7639
Oh Thank You Jesus:-)
Post Number: 7640
Oh Fu*k You Joe
Username: 420alldaylong
Post Number: 1805
Thats why you need to build your own boxes so if something goes wroug the only person to blame is yourself.
Username: Andrew571
Post Number: 869
dang, way to go logan, buildin shitty boxes n all... haha jk, im sure its a shipping damage. Logan wouldnt send a split box
Username: Dakangofkrunk16
Post Number: 362
UPS FEDEX DHL USPS FTL
Picking it up FTW
Building Your Self FTW
Username: Tiki89
Post Number: 78
If almost every screw is stripped thats not shipping damage..... And you should of used wood glue it soaks into the wood making it stronger unlike liquid nails.Thats why you always see experienced box builders always use glue and then maybe liquid nails over it. just my 2 cents
Post Number: 7648
lol I use liquid nails all the time. I dont know hot the hell the screws got stripped...or are they just loose?
Username: Adam_s
Post Number: 1170
I wanna see pics of this box thats falling apart.
Username: Kaos15th
Post Number: 473
GLUE FTMFW
Username: Joebruce
15 Inch Wang...
Post Number: 933
The wood damage was problly from shipping sorry i didnt even think about that. It was problly moved around alot since we had that little shipping problem but its not that bad. And yes some of the screws were stripped and some were just loose but i just got done replacing and adding some screws and i caulked the places that had leaks and it sounds alot better. I mean the box was still way better than i could ever do. Im not trying to make you loose customers or anything Logan,its a nice box for a really nice price and your always fast with your customer service. The box just needed a little touching up. I also just did some fine tuning on my amp,HU, and Epicenter and it sounds alot better. That was problly the biggest problem cuz when i first got it i just threw it in and didnt really tune anything that good and i didnt have time to do it over the weekend. All i need now is some carpet and it will be perfect. I no i need at least 2000wrms to really see what it can really do but its pretty loud for only 1000wrms now. Another thing is i think its tuned a lil too high for my taste,its at 40hz like they recomend but i think it would sound better tuned around 32hz.
Post Number: 7656
Thank You. Thank God It wasnt any major problems.
Username: Goodie_goop
Midland, Texas U.S.
Post Number: 617
hd3's are usually used in higher tuned boxes
Username: Splmonster
C-Town, OH USA
Post Number: 1153
anyone know cutout radius for the hd3 15" ???? plz quick
Username: Jblanford
Post Number: 1184
14"
Username: Oglejust
Post Number: 1728
radius is 7 :-) pay attention joe
Username: Oglejust
Post Number: 1729
btw ogles boxes>logans pos'
Post Number: 7666
lmao Justin lmao
Username: Jblanford
Post Number: 1185
"radius is 7 :-) pay attention joe"
i think he can do the math feg
Username: Th3pwn3r
Post Number:...
Post Number: 2826
Had the box been packaged better I'm sure it wouldn't have sustained any damage.
Post Number: 7671
Well how are you going to package a 100lbs box? It was wrapped in 1/2 inch cardboard.
