Username: Freezeman_7 Lindsay,
Oklahoma
U.S.A
Post Number: 953 Registered: May-06
Tuesday, May 01, 2007 - 01:37 GMT i need to know what else i need for my new memphis mcd2500. i have 1/0 wire, batcap 400, HO alt 200a, big three. what else do i need. i was thinkin like a hc1800 under the hood and a hc800under the seat? i have another amp for my door speakers. so lookin at 2800+wrms
Username: Jblanford Post Number: 883 Registered: Oct-06
Tuesday, May 01, 2007 - 01:40 GMT hc 1800 up front and a 2400 in the back or you could check out the new powermaster batteries
Oklahoma
U.S.A
Post Number: 955 Registered: May-06
Tuesday, May 01, 2007 - 01:44 GMT dont have the room for a 2400 in the back> i could prolly get another 1800 in the back, thats a big MAYBE tho
Username: Mgbcs Lincoln,
Nebraska
Post Number: 1139 Registered: Dec-06
Tuesday, May 01, 2007 - 01:47 GMT I can't wait to see that setup...it will be so nice. Are you picking up the other stuff before the amp or are you getting all of it soon?
Username: Th3pwn3r Post Number:...
Post Number: 2338 Registered: Jul-06
Tuesday, May 01, 2007 - 01:47 GMT The HC1800 is tiny.Put an HC2000 under the hood.
Oklahoma
U.S.A
Post Number: 957 Registered: May-06
Tuesday, May 01, 2007 - 01:50 GMT alright, will that fit in my stock location?? and what in the back, the 1800??. im prolly picking the amp up first ben.
Username: Ctmike Ct.
Post Number: 4177 Registered: Feb-06
Tuesday, May 01, 2007 - 01:58 GMT looking at the kinetik site and using their calculator they suggest a 1400 under the hood and 2 1400s' in the back.
Oklahoma
U.S.A
Post Number: 960 Registered: May-06
Tuesday, May 01, 2007 - 02:04 GMT i jus dont have the room for 2 1400's in the back. i used that to, and im still askin you guys for advice?? like rob said, maybe i could belence it bout with a 2000under the hood and a 1800 in the bak
Post Number: 4178 Registered: Feb-06
Tuesday, May 01, 2007 - 02:13 GMT that sounds good, maybe try to squeeze in a 2000 in the back if possible.
Oklahoma
U.S.A
Post Number: 965 Registered: May-06
Tuesday, May 01, 2007 - 02:25 GMT i might be able to do that.. wont hurt to try
